Old 11-28-2014, 09:50 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Amsoil Signature or Dominator Series?
Which one for a DD car that can get rippen sometimes on the freeway and thru the canyons. I change every 5k miles.
Nighthawk89 is offline   Reply With Quote
Old 11-29-2014, 09:18 AM   #2
cybergrayls3
Drives: 2010 camaro 2ss/rs..m6..CGM
Man to be honest with you if it were me i would go with the Signature series in either a 0w30 or 5w30..both have a higher TBN then the dominator series which in my opinion would be better suited for a street driven car...5k miles is also a very short interval for that oil, almost a waste of money..but i understand oil is much cheaper then an engine. But if your car is running stock engine internals i would atleast go 8k miles on the signature series...or wait until the oil life monitor is around 30-40% if that makes you feel better. Seriously though a conventional off the shelf oil can easily do a 5k drain interval...i would get my money's worth of the signature and atleast run it too 8k or so..Just my opinion..Either oil though is very good..probably about the best money can buy so you cant really make a wrong choice (especially if your adamant on 5k drain intervals)
-Lethal Racing NF cam
-Kooks LT's/high flow cats
-Borla ATAK catback
-CAI cold air intake (black)/Apex scoop
-LSR shifter
-Rick Crawford intake manifold
-Monster level 3 clutch
cybergrayls3 is offline   Reply With Quote
Old 11-29-2014, 01:36 PM   #3
Nighthawk89
Great Advice! Ive always been told 5k intervals so ive just stuck with that. I agree with the recommendation of the signature series.
Old 11-29-2014, 05:57 PM   #4
Andy-AMSOIL
Andy-AMSOIL's Avatar
Drives: bicycle
Or if you are crazy like me you would grow balls to run it for 12000 miles,,, oh and by the by when I send the sample back to the lab its comes back with at least a few more thousand miles of life,, oh and 10 months straight.
I would agree that Sig series would be best,, and can be ran for 8k miles hands down... Dominator if you are looking for the best of the best protection while racing and heavy modified car
Andy-AMSOIL is offline   Reply With Quote
Old 12-03-2014, 10:57 AM   #5
L99CAMA2011
L99CAMA2011's Avatar
Dominator track only. I did however use it for a few days. More torque less cleaning detergents.
Old 12-03-2014, 11:18 AM   #6
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Just make sure you don't use a high end oil like Signature series and skimp on the filter
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-03-2014, 12:08 PM   #7
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Signature series for sure. Dominator if you track alot and change frequently. It has hardly any corrosion inhibitors and is not good to let it sit for long periods of time. I spoke directly with Amsoil Tech on this.
I run Zrod and change to dominator for track use then change out back to Zrod. My motor is way different from yours however.
Signature series is perfect for you.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 12-06-2014, 09:06 PM   #8
Tenring
Tenring's Avatar
Drives: 2014 2SS/RS - SIM
I am running Signature in my daily driver.
Tenring is offline   Reply With Quote
Old 12-07-2014, 09:53 AM   #9
Andy-AMSOIL
Drives: bicycle
For how long....
