12-18-2016, 01:29 AM | #1 |
BUMBL Z
Oil leak on pavers, advice?
As the title reads, unfortunately. Currently have some quikrete cleaner that i'm going to try, but I'm quite open to new ideas. Want to try as much as possible before having to resort to replacing the affected pavers.
Long story short I was in a bind and needed an oil change. Couldn't do it myself since my jack was busted, so I went to a mechanic my dad uses. Got my oil changed there, and found out two nights ago that the oil filter wasn't fully screwed on, so I was leaking badly, but only saw it once it was puddling out from under the car one day.
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
12-18-2016, 09:13 AM | #2 |
Drives: 2010 Camaro Join Date: May 2014
Flip the pavers and wash the dirt off.
12-18-2016, 11:55 AM | #3 |
BUMBL Z
We considered that but we're not sure if the bottom of the pavers we got have contoured edges like the topside do
12-18-2016, 12:26 PM | #4 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
grind some kitty litter into the stain with your heel. wait overnight. sweep. wash area with dawn powerclean dish soap.
12-18-2016, 12:36 PM | #5 |
Pay attention to details
Drives: 2012 ZL1 Join Date: Aug 2016
My father tried many different methods for removing oil from a driveway. He finally used CLR and was very happy with the outcome.
12-18-2016, 12:39 PM | #6 |
Drives: 13 Camaro Join Date: Oct 2016
Use EXimo concrete cleaner you can put it on dry or you can mix it with some water and spray it on. It is what businesses and cleaning professionals use.
12-18-2016, 01:20 PM | #7 | |
BUMBL Z
As for everyone else's input, very much appreciated. Unfortunately turning the Pavers over is not an option as we've been told the design for the Pavers is only top side, so it's either clean or replace. Tried the quikrete cleaner I mentioned earlier, did about 6-8 repetitions of it, letting it sit for the instructed 5 minutes each time (sometimes more) and no real noticeable difference. Also, saw a few videos with people using carb cleaner... Seems sketch, but figured i'd see if anyone here has had any experience with that Sent from my Nexus 6P using Tapatalk
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq Last edited by spadz93; 12-18-2016 at 01:59 PM. |
12-18-2016, 02:57 PM | #8 |
Banned
Drives: Camaro Join Date: Mar 2013
Kerosene
12-18-2016, 07:04 PM | #9 |
Drives: '14 RRM 2SS/RS,GMC Syclone, LPE T/A Join Date: Sep 2016
CRC brake clean in the red can, just used it yesterday on a 12" spill
12-19-2016, 12:00 AM | #10 | |
BUMBL Z
Interesting, just brush and spray off?
I should note that some of these spills are not recent and have been there for a month or two
12-19-2016, 08:16 AM | #11 |
Banned
[QUOTE=spadz93;9462063]Interesting, just brush and spray off
Yes, we used it at my family garage back when it was still cheap. |
12-19-2016, 08:27 AM | #12 |
Drives: 2015 BLK/BLK 2SS/RS MN6 Join Date: Oct 2016
12-19-2016, 09:46 AM | #13 |
BUMBL Z
Brakleen didn't work. Debating the kitty litter trick. Ultimately going to ask the guys who did our driveway (they're family friends) what they would do
12-19-2016, 09:55 AM | #14 |
The eximo I talked about is made up of enzymes that eat the oil. The stain will go away after a week or so. Gas stations, oil industry, and so on use this stuff. You can buy it on Amazon and such. For other methods to work well you have to treat it right away. Eximo works on even old stains and can go deep into the pores.
