05-16-2011, 09:53 AM | #1 |
Drives: 2010 Camaro SS 6MT CGM Join Date: Feb 2011
M6 reverse issue
hey guys wanted to know if I'm only one. When I first start my car in the morning str
U.S. Army 2003-PRESENT {OIF 06-07, OEF 09-10}
/ Airaid / Straight pipes / Morel / Zapco / Kenwood / Lamin-X / Installer at Denton Autosound (940)484-7484 |
05-16-2011, 09:54 AM | #2 |
Reverse gear is rough to get into. Its gets better thru out the day but the first drive of day is rough for reverse. Anyone else?
05-16-2011, 10:04 AM | #3 |
Plays with Hot Wheels
Drives: '17 Jet Black ZL1 Join Date: Apr 2010
My Z06 was tempermental like that occasionally. I forget what the cause was, but I was told to keep the clutch in and move the shifter to "1st" and then back to reverse. I'd do this whenever I felt any resistance when initally going to reverse and it would go in like butter.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring) |
05-16-2011, 11:06 AM | #4 | |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
The clutch is aparently dragging slightly (not fully released) with your foot on the pedal all the way to the floor and the transmission input shaft is still turning with the rest of the gears in the box. That makes it hard to get into reverse with everything still spinning around at different rates. The forward gears have a synchronizer assembly which will cause a little bit of friction as you put the lever into a forward gear. The forward gear synchro will tend to stop the input shaft from turning as it engages and that stops all the gears in the tranny from rotating (breaks free fully at the clutch). Once the gears stop rotating, the reverse gear will be easier to engage. Reverse does not have a synchronizer to slow the gears down before they engage so that is why putting it in a forward gear first helps. The clutch can drag from poor adjustment (on some cars) or from overheating the clutch (abuse/slip) causing heat warpage of the pressure plate. -Mark. |
Similar Threads | ||||
Dealership Screw Up - Clearcoat Issue | FDNY-L107 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 04-26-2011 10:52 AM |
Sequential Tail Light Issue | 40again | Cosmetics and Lighting Modification Discussions | 5 | 03-17-2011 01:33 AM |
Odd clutch and shifting issue for me. | armysig | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 02-22-2010 11:36 AM |
HVAC issue... Anyone had this problem? | nashstat | 5th Gen Camaro SS LS LT General Discussions | 8 | 01-27-2010 04:19 PM |
Another Paint Issue | 2032Ceta | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 08-16-2009 08:59 PM |
