#Camaro6
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Suspension / Chassis / Brakes
Old 06-18-2018, 04:41 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Thumbs up ZL1 Clear Stainless Steel Brake Lines @ Phastek Performance
NOW AVAILABLE!!!!
FREE SHIPPING at Phastek Performance!!!!
Upgrade your factory rubber brake lines to the RST Stainless Steel Brake Lines. These Performance Brake Lines are made with an inner Teflon hose wrapped in stainless steel armor with an overlying layer of abrasion-resistant plastic. These Performance Brake lines will reduce any brake fade that you might occur during a hard track event or even heavy stop and go traffic by reducing the swelling of the factory rubber brake lines.
Features:
  • Kit includes 4 brake lines, 2 - front and 2 - rear
  • Kits come with banjo bolts and washers
  • Inner teflon hose wrapped in braided stainless steel armor with an overlying layer of abrasion-resistant plastic
  • High-quality steel fittings, corrosion-resistant with DOT-compliant collar to protect fitting-to-hose junction
  • Tested in excess of 6000PSI
  • DOT compliance - MVSS-106 certified
  • Greater pressure capability means less expansion under pressure, which results in a firmer pedal, better pedal modulation and control, and insignificant change due to elevated temperature levels from track or race use
Note: Designed and fitted for 6 piston calibers on factory ZL1, ZL1/1LE, and aftermarket GM big brake upgrade.
Clear ZL1 Stainless Steel Lines - #6ZBLCL
Sales@Phastek is offline   Reply With Quote
brake lines, performance, phastek, zl1
