02-28-2014, 04:05 PM | #1 |
Drives: 2014 Camaro SS/RS BRM Join Date: Dec 2013
Klause Question?
About to stripe and polish/seal my OTHER car and have ? about using Klasse.
After I clay/wash then use Klasse AIO, do I need to wash it again before applying the Klasse SG? And after applying the SG and waiting 24 hour for cure, Would I be able to apply some wax, or is the SG enough? Thx If applying wax after the SG is ok, does it need to be washed again first? Last edited by sac130e; 02-28-2014 at 04:31 PM. |
02-28-2014, 09:36 PM | #2 |
So nobody ever used Klasse before with some insight
02-28-2014, 11:13 PM | #3 |
Drives: 2004 Honda Civic+2011 Camaro 2SS Join Date: Sep 2013
Klasse sealant? Works great, is a pain to take off
02-28-2014, 11:16 PM | #4 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
I have used the SG but not the other, I would suggest using a detail spray and a few clean microfibers to wipe it off, that is what I do. I would suggest layering a wax over it but that is my preference. you could leave it as is but I think it looks better with something layered over it.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
03-01-2014, 06:34 AM | #5 | |||
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
If the the car is dirty or heavily dusty, then washing it again is a good idea, but as long as it has been stored indoors, a light wipe down is fine. Quote:
My advice, 1 coat of KAIO - 12 hours - 1 coat of SG - 12 hours - coat 2 of SG... If you want to put wax on top, to add depth of shine (while it will add more protection in theory, Klasse provides more than enough on its own) just wait until the next time you wash the car. |
03-01-2014, 06:36 AM | #6 |
A trick I used when I worked with Klasse as a detailer was to pour a little into a spray bottle. Simply mist it onto the surface and buff it over the surface with a microfiber towel. Keep lightly buffing until you feel the surface become very slick, then flip the towel over and buff off. It always worked like a charm for me, was easy-as-pie, and never compromised durability.
03-01-2014, 01:31 PM | #7 | |
I can wait if it really is needed/helps. Also, a lot of talk about hand applying the AIO and SG. I will be using a PC buffer for at least the AIO, and maybe the SG...thoughts about this? Thx for the info and help |
03-02-2014, 02:58 AM | #8 | |
If using a KAIO on a PC, use a polishing pad and speed 3-4. I have done it this way and it works well. For the SG, I prefer the mist and buff-in method, which is easier in my experience then using the PC for application. |
03-02-2014, 08:05 AM | #9 | |
Thx again |
03-03-2014, 09:48 AM | #10 |
A trick I used when I worked with Klasse was to pour a little into a spray bottle. Simply mist it onto the surface and buff it over the surface with a microfiber towel. Keep lightly buffing until you feel the surface become very slick, then flip the towel over and buff off. It always worked like a charm for me, was easy-as-pie, and never compromised durability.
