04-16-2011, 10:07 PM | #1 |
Seat Harness??
Anyone come up with good options for installing seat harnesses?? I've seen the thread and this website http://www.speedwaremotorsports.com but if I'm reading it correctly its pretty pricey for 2 harnesses, 2 plates and the bar. I do like not having to drill new holes or make alterations.....
Share what you've got or what you've seen, Thanks. |
04-18-2011, 12:17 AM | #2 |
Drives: Twenty-Ten Camaro Join Date: Nov 2010
All Speedware are bolt-in using factory bolt holes, no extra drilling required. I run their harness bar and tank plate. You must use a race seat in order to utilize 5/6 point harness or just run a 4 point harness. Depending on the Org, they may not let you run a 4 point harness alone. Hope this helps.
04-20-2011, 01:44 PM | #3 |
Drives: 2010 Camaro Join Date: Jun 2010
Our setup requires no modification to the vehicle at all.
04-23-2011, 08:49 PM | #4 |
Drives: 2010 Join Date: Jul 2009
speedware motorsports is cheaper than a full cage, and the products go in easily, either that, or drill holes/fabricate brackets.
04-24-2011, 09:05 AM | #5 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
If you are needing a harness then you are needing a rollbar...I dont see the point in the above. Just sayin.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
04-26-2011, 08:40 AM | #6 | |
or know what Speedware motorsports makes then.. As the link in the first post is the only place to buy a harness bar. |
Similar Threads | ||||
Non-RS: Disable your DRL and auto turn on your fog lights with a p-n-p harness | caverman | Cosmetics and Lighting Modification Discussions | 37 | 09-16-2013 01:45 PM |
Tires loosing pressure | joepitt | Wheels and Tires Talk Sponsored by The Tire Rack | 22 | 12-11-2010 05:00 PM |
Exposed foam of seat under the drivers seat / possible seat cover to short/tight | 2010 Bumblebee | 5th Gen Camaro SS LS LT General Discussions | 5 | 08-28-2010 05:12 PM |
SQUEAK/BIRD CHIRP SOUND IN DRIVERS SEAT!!!!! | klondike | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 08-25-2010 12:51 PM |
