Old 10-09-2013, 03:55 PM   #1
cvbfireman
Drives: M6
Stereo upgrade
I thought this thing came stock with a sub. Is anyone. Upgrading just the speakers to get a little more clarity out I it???
cvbfireman is offline   Reply With Quote
Old 10-09-2013, 04:02 PM   #2
Frankzl1
Drives: 2012 Ashen ZL1
Start with the amp, big difference
Frankzl1 is offline   Reply With Quote
Old 10-09-2013, 04:08 PM   #3
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Check out http://********.com/index.php?cPath=1_75 they make a great system for the Camaro along with an amp for the other speakers.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-09-2013, 04:10 PM   #4
cvbfireman
Drives: M6
Cool I've been to 3 stereo shops and they want to replace the deck and everything... I'm really good with that stuff so is rather do it myself
Old 10-09-2013, 04:21 PM   #5
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
I added a powered sub to my car. I have the BA system. I also bought the factory amp replacement harness as well in hopes of replacing the amp one day
45thCamaro is offline   Reply With Quote
Old 10-09-2013, 04:52 PM   #6
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
First thing is swap out the AMP, it like night and day! Lots of other things to change after that.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 10-09-2013, 05:25 PM   #7
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Replacing the amp alone makes a huge difference. I did mine in stages, and when I put the amp in, I couldn't believe how much better the stock speakers sounded.
Sent from my Samsung Galaxy S4 using Tapatalk
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 10-09-2013, 05:37 PM   #8
diverkr
Drives: 2013 ZL1
Just want to clarify. You do not need the X3 cable unless you want to install a subwoofer?
diverkr is offline   Reply With Quote
Old 10-09-2013, 05:38 PM   #9
cvbfireman
Drives: M6
Perfect, that link is where to find it? And is the amp plug and play or will I be cutting wires? I just figured some 6x9s witg tweeters would change the clarity big time but I will start with the amp
Old 10-09-2013, 05:44 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
my .02 is buy a 5 channel amp(alpine has a small one). get a 10" sub. power the factory speakers and the sub to start with.
I have not done mine yet but this what I am going to do. then if I don't like the sound I will upgrade the speakers too.
No reason to change the head unit IMO even you want more clarity just add a cleansweep or something to the system.
now some might say dont' add the sub but I have never been happy with factory speakers and bass output. they just don't work well and usually distort too easy.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 10-09-2013, 05:50 PM   #11
Sven59
HAMMER PILOT
Sven59's Avatar
Everything to the vehicle harnesses is plug n play, of course the battery and ground are not. There is also a connection you can run up to the front for adjusting gain.
This is the system I installed for the sub. http://********.com/index.php?cPath=1_75_77
Old 10-09-2013, 06:19 PM   #12
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1
I've replaced all the speakers and added two 10" subs. I highly suggest replacing just the amp to see how you like those results.
swizlstik is offline   Reply With Quote
Old 10-09-2013, 06:50 PM   #13
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
Definitely try the amp first. I replaced all the speakers and added two 12s. The rear speakers are a pain in the ass to get to. I probably went through more hassle than I really gained in the end.
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 10-09-2013, 07:25 PM   #14
cvbfireman
Drives: M6
http://********.com/product_info.php...roducts_id=449
so thats a 12 and a amp, But this is not the amp that I want correct? I need a 5 channel to bump all the other speakers. Or will this do it?
