Old 11-06-2018, 06:52 AM   #1
San2cci
San2cci's Avatar
Drives: 2013 silver ice metallic ZL1
Reduced engine power...what causes this? Tune?
I was driving down the road after driving all morning and my car started violently shaking and I could only get up to about 10mph. Every light came on the dash. I pulled over and let the car sit and then it started up fine. Now I have a CEL code P2135. I've had an SS 4 years before my ZL1 and never had this happen. I just recently got a email tune from Steve at RDP. That's the only thing I've done differently. Should I flash back to stock? Any help is appreciated. Thanks.
San2cci is offline   Reply With Quote
Old 11-06-2018, 07:42 AM   #2
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
P2135 has something to do with your throttle plate position to the signal it's sending to the PCM. It's a starting point.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 11-06-2018, 08:10 AM   #3
BAH2SS
Stigs Bahraini Cousin
BAH2SS's Avatar
Drives: 2015 Camaro 2SS 1LE
Either throttle body or accelerator pedal position sensor
2015 CAMARO 1LE
https://www.camaro5.com/forums/image.php?u=143224&type=sigpic&dateline=1541618573
BAH2SS is offline   Reply With Quote
Old 11-06-2018, 09:20 AM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Do you have a VTC? that usually causes that
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 11-06-2018, 10:47 AM   #5
WoodBoss
"Old School"
Drives: 2010 2SS L99
What the P2135 code means. This particular trouble code indicates that the Power Control Module (PCM) has detected an erroneous reading regarding the voltages transmitted by throttle position sensor A or B, the accelerator pedal position sensor and or the actual throttle plate. A ported throttle body or one of those Vitesse units could cause this.
WoodBoss is offline   Reply With Quote
Old 11-06-2018, 10:58 AM   #6
San2cci
San2cci's Avatar
I dont have either a ported throttle body or whatever this vitesse thing is. The only thing done differently was the email tune I got from Steve at RDP. Could any of the parameters that get tuned cause this? I'm afraid to drive the car in the event that this will happen on a highway. Thanks guys
Old 11-06-2018, 11:02 AM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
I would reach out to Steve directly, he's usually pretty helpful for troubleshooting.
Old 11-06-2018, 11:50 AM   #8
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
I assume the tune flashed without any problems?
Edit: I see Steve is already on it. I'm sure you guys will figure it out.
HyperV117 is offline   Reply With Quote
Old 11-06-2018, 06:36 PM   #9
fz4k98
Drives: 2013 1ss
Try removing and cleaning the throttle body and mag sensor. It is a known problem on gm vehicles and I had success doing it. The carbon buildup is not much but messes with tps.
fz4k98 is offline   Reply With Quote
Old 11-06-2018, 08:22 PM   #10
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Be sure to check the wires going into the throttle body. These cars are notorious for having issues in the harness at that location
PeteD is offline   Reply With Quote
Old 11-06-2018, 09:05 PM   #11
oslouie
oslouie's Avatar
Drives: 2018 2SS M6 Redline
^^^this. I had the same issue and gradually got worse, enough to the point where it happened 90% of the time leaving work. After some research, I ended up replacing the throttle body and accelerator pedal. The problem never came back. It has something to do with one not being able to communicate with the other, which puts your car into limp mode. You can find a way to troubleshoot whichever part need to be replaced but both were cheap enough on eBay that I didn't bother with narrowing it down.
oslouie is offline   Reply With Quote
Old 11-07-2018, 07:20 AM   #12
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Solid advice from over the years..... its the throttle body needing cleaned tightened etc...or even more likely the Pedal assembly which has the dang potentiometer in it that limits the power by delay with drive by wire.... and others have had to replace one or the other.
Old 12-24-2018, 10:58 PM   #13
San2cci
San2cci's Avatar
Just an update: I installed a new throttle position sensor ($50) rather than installing a whole new throttle body. So far so good. I've driven the car multiple times and I haven't had the issue return. Before it would happen pretty much every time I drove for more than 10 minutes.
This install was pretty easy and straightforward. Just a matter of removing the throttle body assembly from the car and removing a few clips which hold the position sensor in place. May need to adjust the throttle body plate into different positions to get the new sensor to line up correctly. Install new clips and bolt throttle body assembly back on. I also took it upon myself to clean the throttle body while I had it out. It did have some buildup on the plate which cleaned up fairly easily. Also I checked on the connection of the accelerator pedal harness. I removed it and reinstalled it to make sure it had a good connection.
If it does occur again my next step will be to replace the accelerator pedal assembly (about $120).
Merry Christmas!
Old 04-20-2019, 12:41 PM   #14
San2cci
San2cci's Avatar
Some more updating....swapping the throttle position sensor did not solve the issue. It eventually returned. The next thing I did was replaced my accelerator pedal assembly. This also did nothing for me. At this point I returned my car back to the stock tune, and it still eventually went into the reduced engine mode. I brought it to Chevy and they ran some tests and said the wiring is fine and suggested I replace my throttle body. They wanted close to $700 for this so I just picked my car up and ordered an OEM AC Delco throttle body through advanced auto. Had a $50 off coupon so it cost about $180 shipped to my house. I'm reusing the throttle body gasket as it is in great condition. These do not come with the new throttle body and cost about $15. Replacing the throttle body is very simple. I'll update in a few weeks, hoping the new throttle body will correct the issue.
