#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
BeckyD @ James Martin Chevy
Old 02-03-2024, 06:02 PM   #1
Wellgass93
Drives: 2020 2SS Convertible Black
Rattling noise
Hey, I started to experience a rattling noise that grows louder over time, until I get an oil change. The engine starts and is very loud and makes a rattling noise when coming closer to idle. The rattling I thought could be a defective turbo, but that was another issue. It seems to occur in the cold more than in better temps. I thought maybe not having my catch can installed was the issue, I put it in and it connects from my gas cap to my boost block for pvc evacuation (mighty mouse 1200hp wild) I had my oil change three weeks ago, and after the engine was super quiet as it was before. Now after a while the engine becomes louder on, on start especially, and I get a slight rattle. This is the Huron speed twin turbo kit I am using.
So doing an oil change does fix the issue entirely. I have done this twice and each time it goes away. I got the second change because I was doing the catch can install, had the issue with rattling, and since the pvc was not getting proper evacuation to start I did an engine flush. Previous to the flush it was a very noticeable rattle. Also, last time the oil smelt like gasoline due to no evacuation I believe. Only been driven 3k miles since the kit was installed.
Wellgass93 is offline   Reply With Quote
Old 02-03-2024, 06:58 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
“I put it in and it connects from my gas cap to my boost block for pvc evacuation” that’s perfect!!!, I can’t understand what your problem would be?
CalgaryZL1 is offline   Reply With Quote
Old 02-03-2024, 11:16 PM   #3
Wellgass93
Are you saying the might mouse wild is not evacuating? I’m lost honestly car installs aren’t my thing I’m a robotics engineer. But both the turbos and might mouse say to plug that valley port. That’s the valley port? The lower one? That’s what my install shop did anyways.
Old 02-03-2024, 11:57 PM   #4
Wellgass93
“the 1200 is more than capable of 1100
just connect the can inlet to the oil cap and the can exit to the intake manifold
cap of the stock pcv port
and you are all set“
- Mighty Mouse support
Old 02-03-2024, 11:59 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Do you have a manual transmission?
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 02-04-2024, 12:10 AM   #6
Wellgass93
Yes I do
Old 02-04-2024, 12:18 AM   #7
dreksnot
dreksnot's Avatar
Originally Posted by Wellgass93 View Post
Yes I do
Does the sound change when you depress the clutch? Release it? Have it in gear? Driving?
Old 02-04-2024, 12:25 AM   #8
Wellgass93
It seems to react to engine use, a rev can stop the rattle. It got really bad to where it rattled more than not, fairly loudly. I’m not sure if it’s the set screw issue in the transmission, but correlation isn’t causation. It seems to have something to do with oil changes. When the rattle was bad, my engine would roar when starting.
Old 02-04-2024, 12:28 AM   #9
dreksnot
dreksnot's Avatar
I’m asking because a clutch can rattle, rpm dependent. What clutch do you have installed?
Old 02-04-2024, 01:34 AM   #10
Wellgass93
Oem factory clutch 2020 SS
Old 02-04-2024, 09:22 AM   #11
dreksnot
dreksnot's Avatar
Then, clutch is not a likely candidate. I’ve never heard of rattles associated with oil change. You might inspect turbo piping and band clamps. Aftermarket stuff can tend to create new issues you didn’t have before. There are a lot of things that can rattle; NPP exhaust valves, for instant. Exhaust contacting heat shields, the list is long. Best approach I can think of is try and narrow down location and search there for the rattle. Sometimes it will be so the obvious when you see it. Do you think it’s an internal motor rattle?
Old 02-05-2024, 10:46 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
TO bearing?
'20 ZL1 Black "Fury"
catch can, mighty mouse, pvc, rattling noise, turbo
