01-07-2019, 10:48 AM | #29 | |
Drives: ZL1 Join Date: Mar 2018
Do you think a high compression 10:1 376 with a 2.3 Maggie can handle 18+ psi boost on the street? |
01-07-2019, 05:57 PM | #30 | |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Hp per c.i with both engines adjusted to 800 rwhp so you are not comparing flywheel to rear wheel hp, 376 = 2.12 hp, 416 = 1.92 per c.i, the limiting factor being the 2.3 Maggie cannot put out what the 416 wants or needs to fill it's cylinders especially with lower compression, bump the compression up and things changes to a point. 950 on a engine dyno works out to between 760 to 807 rwhp depending on the drivetrain loss factor being somewhere around 15% to 20% range on average. Yes, a 10:1 376 with a Maggie can handle 18+ psi on the street, you do know stock compression is 10.7:1 which would be another story. Tom Hendrix has a 427 with a Maggie making real close to 900 rwhp (1058 to 1125 eng. Dyno Hp), but it's something like a 10.5:1 to 11:1 engine to aid cylinder fill with the 2.3 Maggie, the timing and tune are setup to work with his combination, give him a call. |
01-07-2019, 06:30 PM | #31 |
Drives: All things Turbocharged Join Date: Dec 2010
Engine dyno to RWH is more than just drivetrain loss. You have full intake and real world exhaust system usually. And cooling medium to the blower is a limited, closed loop system. Lot's more losses than just what the trans and rear end takes up. More like 30% and greatly variable based on cooling system temp.
01-07-2019, 07:04 PM | #32 | |
What about the HP and torque curves how will those be affected by the high boost and high compression? Won’t the limit on timing affect the the power curve? Now we are having a great discussion. |
01-07-2019, 09:46 PM | #33 | |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
01-07-2019, 09:47 PM | #34 | |
