Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Vendor and Seller review / feedback / experiences
Old 07-20-2013, 07:30 PM   #1
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
RX Catch can
Got my RX Catch can the other day.
It was easy to install.
It came with all the installation parts, and hose.
Now I just have to drive the car and see how much oil it catches.
It did take a while, but I did get updates any time I asked.
stratman2SSRS is offline   Reply With Quote
Old 07-20-2013, 07:32 PM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Nice looking engine bay. However, I thought those who were running FI should be using the 3 hose set-up. Be sure to check it often until you get a feel for how much it collects. Mine will have approx. 1 oz. per 1000 miles.
Old 07-20-2013, 08:40 PM   #3
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
+1 I thought you were supposed to run with a dual check valve catch can if you went forced induction.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 07-21-2013, 08:57 AM   #4
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
if your boost is under 10psi ,,, 1 check valve is all you need
bmbbl be is offline   Reply With Quote
Old 07-21-2013, 09:26 AM   #5
Dznts
Anabolic Connoisseur
Dznts's Avatar
Looks good
Old 07-22-2013, 09:11 PM   #6
Fish-man
Drives: too many to say!
Dump the check valve. Mine started rattling... went with a regular barbed/npt fitting.
Fish-man is offline   Reply With Quote
Old 07-25-2013, 05:21 AM   #7
stratman2SSRS
I'm only running 7psi of boost.
Single check valve is what Tracy recommended.
Old 07-25-2013, 08:06 AM   #8
SC2150
The checkvalves serve a purpose in regulating the flow and preventing any back-flow, but are not 100% needed if the buzz of it operating is annoying. On a turbo or centri blower they ARE 100% necessary.
Old 07-25-2013, 08:10 AM   #9
redsled
redsled's Avatar
Drives: 2013 ss/1le
Check valves only prevent back-flow. Check valves do not regulate flow. Some flow controls have built in checks, but not all.
redsled is offline   Reply With Quote
Old 07-29-2013, 11:27 AM   #10
mc_acoustic
Drives: 2010 1LT Limited Edition Camaro A6
How long did you wait for your can?
2010 Camaro Synergy Green Edition V6/A6: Cold Air Inductions Intake, Trifecta tune, BBK long tube headers and Hi flow cats, MRT V1, Ported Throttle Body, Stage 4 Ported Intake Manifold (MACE), Black Ice-olator Intake Manifold Spacer, Plenum Spacer, Nytrex Triple Threat Nitrous.
mc_acoustic is offline   Reply With Quote
