01-21-2016, 09:08 AM | #1 |
Drives: 2012 45th Anniv 2SS L99 Join Date: Apr 2014
Coilover choices
I am in need of upgrading my stock 74K (FE4) suspension, I have already purchased all bushings for front and rear as well as subframe mounts and sway bars front and rear. I am looking to get coilovers front and rear and I don't want to get some not so good performing coilover setup that fails to quickly, meaning leaks or needs constant adjustment because of wear and tear or just plain crappy.
I would like someone that has had different coilovers to prioritize them from best to worst with a pros and cons for each brand. My goal is a daily driver that handles like it is on rails and is ready for autocrossing when I am ready to play. Thanks ahead for any input.
2012 2SS 45th Anniversary L99
Kenne Bell 2.8 LC, Kooks Headers, QTP Cutouts, Magnaflow exhaust, ZL1 body and brake conversion, Ridetech Lvl 3 coilovers. |
01-21-2016, 09:38 AM | #2 |
Also interested in this. Looking for choices that will also allow a adjustable drop to make my 22" and 265 and 315/30's look good in the wells.
01-21-2016, 09:38 AM | #3 |
SS
my ridetechs and similar mods took all the body roll out of the corners
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
01-21-2016, 10:33 AM | #4 |
Ridetech coil overs are really well designed and built (in the USA I might add) and they stand behind them with a 1,000,001 mile warranty. They were designed specifically for the 5th Gen rather than just having a different mount welded on a generic setup and don't require cutting a hole in your trunk in order to reach to adjustment like some of the cheaper foreign brands.
01-21-2016, 11:50 AM | #5 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I went with Ridetech, but yet to install them.
01-22-2016, 10:26 AM | #6 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
A friend has them amd says they are good. On a bumpy asphalt street at 25 mph they were softer amd absorbed the bumps better set on a stiff setting the my pedders supercars set soft! From what I have read they are the ones to go with for the price. They are the ones I will go with if needed in the future.
01-22-2016, 10:37 AM | #7 |
Drives: Nickey Super Camaro Join Date: Nov 2008
We use Ridetech coilovers on many of the NicKey builds.
01-22-2016, 04:37 PM | #8 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
Ride Tech Level Two coil overs are a NO-BRAINER for PRICE, QUALITY, & CUSTOMER SERVICE! NO ONE else even comes close!
I have them on my 2010 2SS/RS & have loved them from the first day! Orange 2010 Camaro |
01-22-2016, 04:42 PM | #9 |
01-23-2016, 02:52 PM | #10 |
We have a set of level II Ridetechs with the upper bearing option on the shelf and ready for immediate delivery. PM for pricing.
02-02-2016, 10:58 PM | #11 | |
Drives: 09 GMC Yukon Denali Join Date: Sep 2015
If you come up with any questions about installation or adjustment feel free to call us as well. We all are gearheads and turn wrenches on our own projects and would be more than happy to answer any question you may have! |
02-02-2016, 11:24 PM | #12 |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
I purchased the HQs before she even arrived and were on the car day two. One of the best Mods I've done. Check out my build and look at the videos I put together on post #17. Alot of details on them. Enjoy
http://www.camaro5.com/forums/showthread.php?t=379561 Sent from my XT1254 using Tapatalk
02-03-2016, 12:02 AM | #13 |
Drives: 2011 Camaro SS Join Date: Apr 2015
I'm actually looking for a set of coilovers for drag racing purpose. I have searched and cant find a good opinion/ option. Can a vendor also PM me with an option? I am looking to buy something ASAP. I've been looking into Strange or Santhuffs.. Not sure if I'm even looking in the right direction.
The build is a 427 with 500 shot of spray. So I need something that can perform well. Please let me know on feedback. |
02-03-2016, 01:18 PM | #14 |
Drives: Camaro Join Date: Nov 2014
As another great option for those looking for excellent high quality coilovers. aFe CONTROL has a setup for both the street/track and drag racing disciplines.
(Street/Track Versions) http://afepower.com/shop/details_new...ro&brandID=142 (Drag Racing Versions) http://afepower.com/shop/details_new...ro&brandID=142 |
