04-30-2014, 09:15 PM | #1 |
Drives: 2012 Black Camaro 2SS Join Date: Jul 2012
Window regulator clunk noise, horrible service in Orlando
Well I've about had it with my dealership here at Carl Black in Orlando. I just recently had a window regulator replaced for making a noise when the driver window went up. Ever since the regulator was replaced I've had nothing but issues.
First they split a plastic piece above the driver side mirror and without doing proper research replaced the entire mirror because they thought the plastic part was apart of it. Well after they did that I've had a terrible wind noise that they continue to deny coming through the driver window. I've tried reindexing the glass and tomorrow I'm gonna try some solutions I saw on here. The dealership told me that they've sent it up to Chevrolet engineers, but who knows. Anyways the technician Junior who works on my car seems to take any shortcut possible and when replacing my door panel overtightening the screw damaging the door panel expecting me not to notice they return the car. Needless to say the door panel has been replaced, however now I continue to get the same wind noise and a loud clunk when the window rolls all the way down. The service manager as usual says its normal and the window is hitting the stop however the noise is pretty loud. If anyone can chime in on this, I'm gonna attempt to fix the issue myself since if I bring the issue to another dealer, they will most likely tell me to take it back to where it was originally worked on. I appologize for the long rant, I'm just thorougly disappointed in the way this has been handled. If anyone can chime in and help, I'd appreicate it. |
04-30-2014, 10:50 PM | #2 | |
Drives: GM Vehicles Join Date: Jun 2010
William R. Chevrolet Customer Care |
04-30-2014, 10:51 PM | #3 |
Drives: 2010 Camaro 2SS/RS LS3 IOM Join Date: Aug 2012
I wouldn't think they would "force" you to bring your car back to the original dealer. Especially if you complain about the service you received there. They would have an opportunity to gain a new customer, and any $$$ they can make off of you. I have zero wind noise, so I call bs.
05-01-2014, 08:54 AM | #4 |
bump
05-01-2014, 08:54 AM | #5 | |
Yeah gonna give another dealer a try hopefully GM will make it right |
05-01-2014, 09:25 AM | #6 |
Drives: 2011 Camaro 2LT RS Convertible Join Date: Jul 2011
I wouldn't fiddle around with anything that's part of the problem unless it's an immediate safety concern!
The parts and labor are under warranty. let them handle it. If you take it to another dealer, that's fine, as well, but don't try to correct any work that's been done until it can be re-inspected.
Summit White Black Leather 3 Pedals Build Date: 06/27/2011 Purchased: 07/30/2011 Title Received: 08/15/2011 1984 Camaro (3rd Gen.): Traded: 1987 "Meet the new boss. Same as the old boss." |
05-01-2014, 10:44 AM | #7 |
Yep. Find another dealer. There must be several around Orlando. Don't hesitate to get William R involved. That's what he's here for and he should be able to help satisfy your problem.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-01-2014, 10:58 AM | #8 |
What kind of noise was it? Look at my last thread that I made and watch the video I attached and let me know if it is the same noise? Because my passenger window is making a funky noise when I roll it up or down, also. If you could do that, that'd be great!!
Here is the video: http://youtu.be/JrANhWDIHeY
05-01-2014, 11:05 AM | #9 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
I had a similar issue with mine. The window motor bolts to the regulator and the plastic bolt holes tear out. The noise is probably the motor being loose.
Mine was replaced twice. I have wind noise and have not taken it back. The window is adjustable but the tech is supposed to test drive the car to assure that it is sealing properly
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
05-01-2014, 12:25 PM | #10 |
I'll probably offend you
If another dealership tries to give you hassle over warranty work get the reps here involved. Your warranty is NOT through the dealership you bought the car from, it is from GM.
05-01-2014, 01:47 PM | #11 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Sorry for the issues but I will say the only two dealerships who I will allow to work on my vehicles is Starling Chevrolet (St. Cloud), and David Maus Chevrolet (almost all of the tech's came from Classic Chevrolet).
Good luck
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
05-01-2014, 01:55 PM | #12 | |
Can't say it's the same noise. Mine tends to clunk when it rolls down. The original reason I had it replaced was when the window rolled up it made like a creaking noise. Hopefully you get your issue figured out. |
05-01-2014, 01:56 PM | #13 | |
Yea it kinda sucks Carl Black is right by my house, but I've heard good things about David Maus. Whats the last thing you had serviced there? |
05-01-2014, 01:57 PM | #14 |
Amen to that, I called the customer support line today and GM has a case open, lets see if any progress can be made.
