11-21-2012, 11:23 PM | #1 |
Drives: 2013 Camaro Crystal Red Tint Join Date: Aug 2012
New Amp to replace factory Boston Acoustics
What amps have you used to replace the original Boston Acoustics amp? I am looking to use the ********er bracket and wiring kit. I need an amp that will fit in the factory location (I need the room for a set of golf clubs). I have found 3 that seem to fit JL Audio XD400/4, Rockford Fosgate Prime R400-4D, Pioneer GM-D9500F. Have you had any problems with noise, radio reception, or thump when the amp turns off?
11-22-2012, 01:26 AM | #2 |
Drives: 2011 Camaro Join Date: Mar 2012
Tagged for responses . . .I'd like to know what others are using as well.
11-22-2012, 02:18 AM | #3 |
I've done a little looking and found these for ideas . . .
Alpine PDX series PowerBass XAX Mini's or ATM compacts |
11-22-2012, 03:41 AM | #4 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
The jl audio xd 700/5 will fit
11-22-2012, 06:28 AM | #5 |
Drives: 2SS/RS M6 Join Date: Apr 2008
I've had the JL XD400/4 with the ******** kit you're going to use for over a year now and it kicks ass. It really wakes up the stock system and it's expandable. If you want to add a sub down the road, it's a real easy upgrade. Adding this amp with the ******** FARK harness makes the stereo sound like it should have from the factory. Those Boston speakers can handle more power than that shitbox stock amp provides.
No problems with doing this mod. No reception problems, noise or anything. I used the FARK kit and followed the directions for it and the amp. The harness is quality plug and play item. As long as you follow the directions and do a clean install the only difference will be your system will WAKE UP! Last edited by RobertHarriSS; 11-22-2012 at 06:38 AM. |
11-22-2012, 09:02 PM | #6 |
Drives: 2011 Camaro RS M6 Join Date: Jan 2011
I researched the Rockford Fosgate and the JL XD400/4 amps you listed. No one ever said a bad thing about the JL so I spent the extra money on the JL and couldn't be happier. Due to the high level inputs from the factory head unit and no line out converter you need to keep the input level/gains low on the JL. I have a very slight 'click' when the amp shuts off that I just noticed. It by no means is a pop. It is a very faint 'click'. I ended up replacing my front door speakers with Alpine 6.5" coaxials. I also took the upper boston tweeters apart and placed a single layer of paper towel over it and put it back together. Those have a horrible tone to them with the extra power. The paper towel is perfect. (I think I am going to try some thin landscaping underlayment since it is plastic and won't absorb water). I have a separate sub amp and 12" sub. Now I am looking to replace the rear 6x9's. While the new amp helps the factory speakers greatly, replacing them with a good set will really show you how clean the JL amp really is.
11-24-2012, 01:23 PM | #7 |
bump
12-08-2012, 11:44 PM | #8 |
I just came across these. They look like they put out more rms wattage than any of the other's I have found.
I have polk audio 6.9's that have a rms rating of 125 and 4ohms, and so far, this comes the closest in rms. https://www.massiveaudio.com/product...tal-amplifier/ |
12-09-2012, 04:02 AM | #9 | |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
12-09-2012, 04:06 AM | #10 |
The PDX amps mentioned by glockman are very good amps. I have a mono 1000W and a 4 way 600W I've had for 6 years and they work great. I also have a second 1000W I got about 4 years ago.
12-09-2012, 02:54 PM | #11 |
CWI, I think the stock tweeters sound just fine hooked up with the Alpine coaxial door speakers. It's really no different that the way the factory had the tweeters hooked up. I thought about going component and may eventually but I felt the front was missing some highs so I went this route. Just replaced the rear speakers and finally this sounds like it should. Those stock rear 6x9s are so dang flat sounding even with the JL Audio XD400/4 amp.
12-09-2012, 04:54 PM | #12 |
Drives: '11 2SS, '11 C6 GS, '04 MDX Join Date: Feb 2012
Sorry for the hijack. I don't think I need/want a sub right now and I'm not really interested in swamping speakers, so would getting a JL XD and FARK really improve the sound enought to make it worth the investment? That is what I have been considering - and I also want to place it in the stock location like the OP.
12-09-2012, 05:02 PM | #13 |
$350 for the JL Audio XD400/4 amp
$115 for the FARK kit $50 for RCA cables and the power and ground cables for the amp So over $500 and you still have the stock speakers. I do not think it is worth it if you don't go all the way and replace the speakers at least. |
12-09-2012, 08:54 PM | #14 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
