09-11-2017, 06:21 PM | #1 |
Drives: 12 camaro ss Join Date: Apr 2016
Carpet removal
I am trying to remove the carpet i have everything out but im stuck on the front part.. do i have to disassemble the dash to take it off or what? Couldnt find a DIY.
09-13-2017, 11:57 AM | #2 |
Drives: 2014 2SS/RS Join Date: Dec 2014
That area behind the dash mount bracket is completely hidden by the console.
Couldn't you just take some little sewing scissors and cut a small slit where I marked in red on the following picture and then slide the carpet backward and out from under the dash?
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
09-13-2017, 01:19 PM | #3 |
Drives: 2011 1LT Join Date: Mar 2012
Just an opinion, but I would certainly agree with cutting the carpet as you've suggested. As long as you are careful not to inadvertently slice any wiring that might be hidden under there, I cannot see how that could a problem.
09-13-2017, 01:26 PM | #4 |
Carpet removal
Yea thats what im going to do brilliant idea thank you guys!
09-14-2017, 09:34 AM | #5 | |
Ron
09-15-2017, 08:08 AM | #6 |
Drives: 1969 R/S Z28 302 m20 Endura Join Date: Sep 2009
FWIW if you unbolt the dash supports they can be bent outwards aboyt 1/2" or so, enough to get carpet pulled back and installed may have to apply pressure on supports to get bolt started then tighten them downand your good - no cutting of carpet needed
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone 2015 Zl1 |
10-22-2017, 11:33 PM | #7 |
Drives: 2014 2SS/RS/LS3 Join Date: Mar 2017
Gio don't tell me that you got water in your car bro ):
