06-09-2010, 12:18 PM | #1 |
Using Hands Free Bluetooth
I've connected my Blackberry Storm2 to the car and i'm trying to sync the contacts to the car. Is the possible without having to go through and manually tell it the number and name to store with each person?
06-09-2010, 06:08 PM | #2 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
Unfortunately, you have to do it manually...
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
06-14-2010, 02:05 AM | #3 |
Drives: 2010 Camaro 2LT RS Join Date: Jun 2010
If you're trying to store them just so you don't have to say dial every time and enter a number, here is another way I found out how to make a call and it works way better! Hit the voice command button and the say bluetooth, pause for beep, and then say voice.... this allows the car to access your BlackBerry's voice command and that way you can just say call ####.... works great with my iPhone and should do the same with a BlackBerry.
08-02-2010, 11:11 AM | #4 |
You Said Member
Drives: 2010 SIM 2LT Auto RS Join Date: Feb 2009
edit: fyi only the steering wheel button will give you this option.
