Old 03-01-2024, 02:07 AM   #1
RoadRunner70
Drives: Chevy Camaro SS 2012 Auto/TR
Question SS doesn't accelerate more than 135
2011 Camaro SS auto/t, stock. Installed hubcentric wheel spacers. Mileage 121.000, gasoline 87,
This is not the first time I have noticed this. When approaching about 135 mph, noticeable vibrations and shaking begins. Looks like the car doesn't want to go faster than 135 mph, acceleration becomes very sluggish. Tranny in S mode and stabilitrak in competitive mode.
Previously I drove up to 155 mph without problems.
Maybe this is related, not sure. The fuel pump was replaced several months ago with the original one GM MU1959.
When fuel level is low (about 40 miles) the car starts to drive poorly and the traction disappears. Or sometimes it throws CEL related to the fuel pressure sensor or fuel control module. After refueling defect dissapears.
Idle fuel pressure is 3,9 bar per OBD readings.
Any suggestions?))
RoadRunner70 is offline   Reply With Quote
Old 03-01-2024, 04:28 AM   #2
bsn
Drives: 2013 ZL1
The first thing I would do is run 93 if you can get it, if not 91. 87 is an absolute no-no when your doing any type of performance driving. Second thing is NEVER do any performance driving with an empty tank, your sucking air and running lean and overheating your fuel pump, leading to burnt pistons and failed fuel pumps.
bsn is offline   Reply With Quote
Old 03-01-2024, 06:27 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
+1
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-01-2024, 07:50 AM   #4
gtstorey
What is fuel pressure when having the problem. Fuel pressure at idle doesn't mean much when the problem is WOT.
Old 03-01-2024, 08:39 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
+2 on this. 87 fuel isn't supposed to be used in an SS unless it is an emergency and you need fuel and can't get premium. Sos you shouldn't run the car hard at all with 87, knocking and detonation could accur and possible engine damage. Run a couple tanks of 91-93 through it and due the fuse pull reset.
https://www.camaro5.com/forums/showthread.php?t=38964
Old 03-01-2024, 09:18 AM   #6
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Must be running that Pemex fuel while doing top speed runs in, "Mexico", huh?
Moto-Mojo is offline   Reply With Quote
Old 03-01-2024, 09:55 AM   #7
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Furthermore, once you've ran 87 in the early 5th gen SS, due to a software glitch you are stuck on the low octane fuel table and the only way to get back on the upper is to do the 5 & 20 fuse pull. IDK, they may have never fixed that for any model year 5th gen. Even made a sticky for this issue
Old 03-01-2024, 10:03 AM   #8
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Pemex bought Shell Deer Park in Houston sir. So there’s a USA Pemex refinery….
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 03-01-2024, 10:35 AM   #9
d2cheer
Drives: 2013 2SS Vert, 1968, 1971 Camaro
Is the 2013 affected by this?
Thanks,
d2cheer is offline   Reply With Quote
Old 03-01-2024, 10:45 AM   #10
Wizard1183
Wizard1183's Avatar
Thanks,
Yes, all SS Camaros are
Old 03-01-2024, 10:58 AM   #11
Leadsled
Leadsled's Avatar
Drives: 2010 Camaro SS 6MT
THIS!
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
Leadsled is offline   Reply With Quote
Old 03-02-2024, 07:22 AM   #12
redcoats1976
i can see why it would be shuddering and shaking at 135 running 87 octane,lucky if it hasnt been damaged by that.
Old 03-02-2024, 10:42 AM   #13
RoadRunner70
Thank you for reply, I will check it next time.
What is the good readings regarding fuel pressure and flow rate ? Maybe I installed the defective fuel pump ) I found one SPECTRA PREMIUM SP6681M with min flow rate 80 Gph and 75-85 psi
Old 03-02-2024, 10:46 AM   #14
RoadRunner70
I would be glad, but I live in such a hole that there is nothing nearby except 87 gasoline. I tried adding 0,5 gal 99% isopropanol but didn't see any difference.
