04-07-2013, 10:50 PM | #1 |
Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
Oil change, now 15 degrees hotter ?!
Just noticed today first day out after an oil change, I am running about 220 when she used to run 205
I am thinking pull the oil and filter to start off the oil change was done in conjunction with a new pan gasket. Use synthetic only |
04-07-2013, 10:53 PM | #2 |
220 is normal operating temp
04-07-2013, 10:56 PM | #3 |
Yeah I thought so too but I always was running a little cooler?
04-07-2013, 10:57 PM | #4 |
It is warming up outside too could be a factor as well.
04-07-2013, 11:19 PM | #5 |
Yeah, could be, it's been awhile since I have had it out of the garage, maybe I just forgot how hot she burns, lol, today was the first day out since winter storage, I'll keep my eye on it for the next several times out,
04-08-2013, 12:22 AM | #6 |
Drives: 2015 Challenger SRT Join Date: May 2011
Have you checked and topped off your coolant level?
My SS runs between 195-210*F with the coolant at the appropriate levels. |
04-08-2013, 07:59 AM | #7 | |
I don't know if your 20 degree increase is a big concern but I also don't think you can chalk it up to it being a little warmer outside. It can't be very hot in Chicago in April. IMO it would have to be a significantly higher air temp than what you see this time of year to make the oil temp climb. I think wait, watch and check fluid levels is a good plan for now.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
04-08-2013, 11:19 AM | #8 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Try running the heater on full hot to move any bubbles out of the heater core.
I see 220 occasionally in stop and go traffic. Oddly it seems to happen more often with temps < 45 deg. Maybe because the fan does not come on as easily. |
04-08-2013, 02:31 PM | #9 |
You know that makes real sense because we were at 45 to 55 and the fan was not turning on, I did not think about that. last year it would have to get pretty darn hot outside for me to hit 220 and it would be in stop and go typically, I am going to check the fluids and run the heater. Well , both good suggestions as well.
04-08-2013, 04:08 PM | #10 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Umm it is ~70* out today, don't panic 220 is normal. Drive it.
04-08-2013, 07:43 PM | #11 |
Drives: 2010 SS/RS 6 Spd Manual IOM Join Date: Aug 2009
My oil temp has been at 220 since day one, I do live in Nevada where its warmer than most areas most of the year.
2010 2SS/RS, 417 stroker, 4.0 Callies crank and rods, JRE pistons w/hellfire nitrous top rings, Kooks 1 7/8 LT, Kooks 3" Exhaust, CAI Intake and Scoop, Cam SullivanGM W/ Hardened PR, Stock Heads. Dual Springs, Mcleod RXT Clutch, Hurst LL W/ Cruise Momentary, GM 3.91 gears, Nitrous Outlet direct port 200 shot, Dedicated Fuel Cell(C16), LNC2000 and NOS Mini controller, BMR suspension w/Bushings, Pfadt Drop, Pfadt Diff Bushings, 1400hp DSS Axles, DSS driveshaft, Solid Engine Mounts, Razzi Body Kit, Speedhut Gauges,T-REX Phantom Grills (Black) 533RWHP/500RWTQ N/A, 724RWHP/816RWTQ 200 Shot
04-08-2013, 08:15 PM | #12 |
Drives: 2011 IOM 2SS/RS Join Date: Dec 2010
This!
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
