Old 10-01-2019, 10:26 AM   #1
superchris
TRI-COUNTY CAMARO'S 3CC5
superchris's Avatar
Drives: 2010 Red 2SS/RS M6
LS7 ENGINE ON A CAMARO SS?
CAN A LS7 CRATE ENGINE PLUG AND PLAY IN A 2010 CAMARO SS MANUAL?
I WONT NEED TO REPLACE THE TRANSMISSION CORRECT?
OR COMPUTERS?
THANKS!
superchris is offline   Reply With Quote
Old 10-01-2019, 10:29 AM   #2
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Yes, You should be able to plug and play a crate LS7 engine into a Camaro with an LS3 from the factory.
Katech_Zach is offline   Reply With Quote
Old 10-01-2019, 10:58 AM   #3
superchris
superchris's Avatar
How about the engine harness or computer?
Old 10-01-2019, 11:21 AM   #4
G8One2
Drives: 2014 Camaro 2SS
What he's saying is, take it Katech, they will handle it for you.
G8One2 is offline   Reply With Quote
Old 10-01-2019, 11:27 AM   #5
superchris
superchris's Avatar
bottom line is that i'm going to need a new engine.
not sure which route to go.
perhaps stick to factory ls3 block, or switch to ls7 or perhaps a LSX crate engine.
Or even the LT1 wet sump.
Old 10-01-2019, 11:33 AM   #6
Reichler
Reichler's Avatar
Drives: 2004 GTO & 2005 GTO
Well, it may bolt in, but it's certainly not plug-n-play. You're going to need to have someone with HP Tuners or EFI Live calibrate the ECM.
Reichler is offline   Reply With Quote
Old 10-01-2019, 11:42 AM   #7
G8One2
LSX454 would be what I'd spring for, but that's just me.
Old 10-01-2019, 12:41 PM   #8
Katech_Zach
I misinterpreted the initial question. The engine will bolt in, and the harness should be the same. You will definitely need to tune the ECU to run the engine properly.
Old 10-01-2019, 12:44 PM   #9
rshelar
rshelar's Avatar
Drives: 2017 1SS auto vert Nightfall Gray
Well... I traded my 2015 L99 for a 2017 LT1 primarily to get that bullet. Plenty of power and torque without the additional weight of the LS7 or LSX. If you haven’t driven a gen 6, try it.
rshelar is offline   Reply With Quote
Old 10-01-2019, 12:48 PM   #10
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
I've heard of a lot of issues with the LSX454. The LSX 427 is a much better engine.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 10-01-2019, 12:54 PM   #11
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Z28 comes with the LS7 but has all the stronger components to match. Food for thought.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 10-01-2019, 12:59 PM   #12
rshelar
rshelar's Avatar
Right on. I had a buddy that had one in Florida and used it primarily as a track car. He was a contractor and his Chevy dealer kept calling him trying to get rid of it. They were very pricey!
Old 10-01-2019, 01:11 PM   #13
G8One2
Interesting, I had not heard that. What issues do they have?
Old 10-01-2019, 03:17 PM   #14
pyroguy
pyroguy's Avatar
Drives: ABM #831
I cannot remember the specifics off the top of my head, but it was internal components of the engine itself. There's a thread here from a guy that went through 2 or 3 blocks on a LSX 454 right out of the box with trouble.
