07-03-2020, 12:13 PM | #1 |
Counting down the days...
Drives: Black 2011 2SS/RS Join Date: Mar 2011
BMR rear sway bar
2011 Camaro SS BMR rear sway bar with mounts and bolts. Local pickup only. Asking $120 OBO, located in Fort Walton Beach, Fl.
07-03-2020, 02:30 PM | #2 |
Drives: 2011 2SS/RS Join Date: Feb 2016
Should note this is for 2010-2011. the later 12-15 are different
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
07-03-2020, 05:10 PM | #3 |
07-04-2020, 07:00 AM | #4 |
Just have to say sup to a brother one county over lol.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
07-07-2020, 09:42 PM | #5 |
07-15-2020, 12:10 AM | #6 |
TTT
07-15-2020, 12:46 AM | #7 | |
They may be different, but the LCAs still have the perch for the dog-bone end-links. You only need to use those instead of the rod type end-links. The only way this would not work is if the bolt on location for the brackets changed on the cradle, and there is no perch for the end link to bolt to. I was told, AS long as the LCA has the end link bolt-on location, it will work. I am upgrading mine to a 2015 rear sway bar, so I needed to buy 12-15 LCAs for the end links, that's it. Those MOOG LCAs have both mount locations for either sway bar's end-links. |
07-17-2020, 10:22 PM | #8 |
TTT. Open to reasonable offers!
