Old 05-13-2021, 08:28 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Any electricians in here? LED wiring question.
I got an LED wire kit (40 ft). It comes powered by a 120V plug in wire, with a 12v output from the plug in box. The wire supplying power to the LEDs is 22AWG. I want to cut the plug/box off and wire it to be powered by a marine battery. All connections will be soldered & heat shrunk. My question is:
1) can this be safely done?
2) what size on-line fuse should I use?
Thank you!
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
Cornflakes'Camaro is offline   Reply With Quote
Old 05-13-2021, 11:15 PM   #2
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
Thank you!
Yup totally safe! LED's are low voltage and draw very little current. Since they are low voltage the fuse in a dedicated circuit should be 5A or less as most 22AWG wire is rated for about 6-7A. To be be on the safe side a 2.5A fuse would easily protect the circuit. What you are doing is basically making sure the fuse is the weakest link in the circuit and it will burn out before your wiring. Of course there are other factors involved such as LED chip type and length of the strip but you will find almost all LED strips are wired with 22AWG which is used for low power distribution.
davesnever is offline   Reply With Quote
Old 05-14-2021, 07:09 AM   #3
Cornflakes'Camaro
Awesome Dave, thanks for replying. So I dont have to worry about the battery over powering the LEDs and turning them and whatever they are mounted too into melted liquid?
Old 05-14-2021, 09:32 PM   #4
davesnever
davesnever's Avatar
No you are fine, I have added 3 strips in my trunk directly off the interior light circuit and also run a 20ft. strip around the perimeter of my engine bay that is wired into headlight circuit. As I recall I have a 2.5A fuse on the engine bay one and the trunk I just tapped into the circuit and left it unfused because the BCM is already protected. I did use a larger guage wire to feed them of course.
