05-25-2017, 10:14 AM | #1 |
Drives: 2015 Grey 1LT Join Date: May 2017
Sway bar help
Hello I've done alot of lurking around here and I can't seem to find the specific answer. I want to upgrade my rear sway bar in the most economical way and have been looking at the ZL1 bar. My question is what do I need to do upgrade specifically do I need the lower control arms? I have a 2015 1LT V6 Manual. Thanks in advance.
05-25-2017, 10:49 AM | #2 |
Nutcase
Drives: "Black Beauty" 2015 1lt in black Join Date: Jul 2016
the control arms are fine I just upgraded my 2015 LT to a 1le bar. Look down right by the back of your rear spindle you will see a hole that's where the drop links go. Make sure to get the drop links with the bar they are very different to the V6 links. and the bolt head goes down on the links otherwise they hit your wheels.
05-25-2017, 10:53 AM | #3 |
Sweet thank you that's what I was hoping for!
05-25-2017, 10:55 AM | #4 |
Where did you get your bar I was planning on going though GMPartsdirect.com and was curious if it came with the mounts
05-25-2017, 11:43 AM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
Wouldn't hurt to get a quote from a dealer for a new bar. The new bar won't come with the mounts but you can keep the mounts you have now, but you'll need new bushings for the mounts as the bar will be bigger. Not sure of the part number for the bushings but GMPartsDirect might have them, or again you can try the dealer.
05-26-2017, 10:54 AM | #6 |
Nutcase
my bar came from LKQ via eBay I paid $199 for everything. If you go the eBay route make sure to check the part numbers because an SS bar is way smaller than a ZL1 or 1LE bar
05-26-2017, 02:16 PM | #7 |
Drives: 2011 Camaro 1SS Victory Red Join Date: Jun 2016
I would talk with JPSS. I got my sways from him. He has never pointed me in the wrong direction. I have never heard anything bad. His products and quality are top notch. I would give him a shout. http://www.jpssonline.com/ (276) 644-0100
2011 LS3 M6 Rotofab CAI, Comp Custom Grind Cam 224 / 234 @ .050, .581/.576 w/ 1.7 rocker, 114 lobe sep 110 int c/l, Borla Full Exhaust, Ridetech Stage 2 Coilovers, McLeod RXT Street Twin Clutch, JPSS front and rear sway bars, JPSS caster locks, Forgeline GA3R Wheels Victory Red inner and outer barrels and matte back Spokes wrapped in Bridgestone 305 re71r on all four corners, Other JPSS Stuff. 455RWHP and 411RWTQ on Nascar Dyno.
05-27-2017, 08:15 PM | #8 |
Drives: Camaro Justice Join Date: Jun 2007
A new rear bar from GM should be a ZL1 or 1LE and both the bars should ship with the sway bar bushings and straps attached. You will need to order two drop links as well. Both these bars are 28mm.
My JPSS rear bar is $100 more than the internet price shown in this thread. It is also a bigger bar and that is a big deal on the 5th Gen. The bigger the rear bar the more balanced the car becomes. |
05-27-2017, 09:13 PM | #9 | |
Drives: 2015 2SS 1LE Join Date: Dec 2011
05-28-2017, 08:29 AM | #10 |
So I ordered a ZL1 bar and links from gmpartsdirect for ~$150 with shipping. Once I complete my transfer to Miami next month I'm going to look into exhaust, bushings, and springs. Thanks for the input from everyone. I may try to do some Autocross here and there but for now I got to find a place with a sweet garage.
09-09-2018, 11:30 AM | #11 |
Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
2015 Stock SS
What sway bars are the best for street use?
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
09-10-2018, 09:29 AM | #12 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
It’s all preference. On the street, realistically the stock 28mm zl1 rear bar and your stock bar is a good balance and won’t stiffen the rear much over one wheel bumps. Bigger bars while giving flatter cornering are more then you can ever use safely on the street.
09-10-2018, 12:39 PM | #13 |
I was thinking of putting OEM 1LE sway bars on my 15 SS, any concerns with doing this considering i have a staggered wheel set up?
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
