06-26-2022, 08:12 PM | #1 |
Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Whole slew of new codes
I have just put on my rear drag pack, 17x10 with 305/45r17, made a test hit and blew my AC belt off, lol. Didn't think much of it, i dont mind driving around without a parasitic relationship for awhile, but anyways.
I drove around pretty much all day and have no issues other than being hot, until later that night when i made a couple more hits, and then went to the liquor store. I turned my car back on after being inside for about 5 minutes, and noticed my CEL was on. Here's what she wrote: P26C8 P12E7 P12EB as well as some other codes that I'm unclear if they're new or old because of the way hp tuners explains it, so there's a little confusion there. But here they are: B3110 (Pending, History) C0760 (Pending, Current, Old, History) C0765 (Pending, Current, Old, History) C0800 -Device power circuit malfunction (Pending, History) I will add that the car doesn't seem to me at least, to be running or driving any different. I will also add below the details of my car: 2019 Camaro SS btr cam, d1x procharger (10-14 psi give or take), e85, piston rod combo, new valvetrain because of cam, kooks headers, no cats, Circle D 3600 stall, and there might be some things that i am missing, but i feel like the are the more important mods that might play a part in all of this. |
06-26-2022, 10:49 PM | #2 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Relocate wire harness in rear? Maybe new wheels/tires got into it?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
06-27-2022, 03:52 AM | #3 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
https://youtu.be/zd_gMnHkk70
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
06-27-2022, 06:29 AM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
The P12 codes seem to be related to the AFM valves in the exhaust. Maybe they’re old codes from when you installed the headers and other modifications?
06-27-2022, 02:06 PM | #5 |
very well could be in but when i got up under the car i didn’t see any rubbing. in fact it looked like it had a fair amount of space. enough to get my hand between. could have hit a bump though. but how close are the harnesses to the engine bay? because when the ac belt ripped off it could have hit something too. but i can’t find any diagrams to show where things are at
06-27-2022, 02:07 PM | #6 |
06-27-2022, 02:38 PM | #7 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Would like confirmation on this if possible.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
06-27-2022, 03:46 PM | #8 | |
https://www.camaro6.com/forums/showthread.php?t=606911 |
06-27-2022, 07:23 PM | #9 | |
06-27-2022, 07:25 PM | #10 |
Tags |
cel, check engine light, code checkengine, dtc, help me |
