Old 04-12-2010, 05:32 PM   #1
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
What trans fluid to use
Lately my M6 feels a little notchy, sometime I feel like I have to force it in a gear at certain speeds. So I was thinking about changing the trans fluid to Synchromax? Or does anyone else have any other suggestions?
1200 miles on the clock.
2010 Camaro 2SS/RS/LS3 -Black on Black - Kooks 1-7/8 Headers, Dyno Tuned, ADM Race CAI, QTP Cutouts, Hurst Short Throw, SJM Line Lock, Alpine PDX 1.1000, (2) Alpine Type R's, ...Soon to be cammed!
HaZe_X is offline   Reply With Quote
Old 04-12-2010, 05:55 PM   #2
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
I was going to change to 4.2 qts of Redline 75w90NS in the trans, but couldn't find any that day.
So i went with 4.2 qts. Mobil 1 Synthetic ATF Dexronn III spec. It did help with the clunky feel a bit on the 2nd to 3rd shifts when cold.
Freekin' smelly stuff, don't get any on your exhaust pipes like i did, the smell lasts awhile...
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 04-12-2010, 09:41 PM   #3
HaZe_X
HaZe_X's Avatar
Thanks, I Have it narrowed down to the M1 or RP, just trying to get everyones opinion. Also my issue isnt when it cold, its smooth as butter when its cold, the problem is when it starts getting warm.
Old 04-12-2010, 10:27 PM   #4
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
Just changed to the M1 Synthetic ATF. Man what a difference! great stuff!
gotpball44 is offline   Reply With Quote
Old 04-13-2010, 08:55 AM   #5
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
RP but this is personal prefrence from using both brands
Gentry78 is offline   Reply With Quote
Old 04-13-2010, 11:53 AM   #6
hollywoodjose
hollywoodjose's Avatar
Drives: 2010 Black 1LT
So is the gm dexron vi good? That's what is in the manual and I got 7 quarts from my dealer but haven't put it in yet. I was going to use mobil1 synthetic but in the manual it said dexron vi so I didn't know what else to do. Mine is automatic and v6
hollywoodjose is offline   Reply With Quote
Old 04-13-2010, 12:25 PM   #7
Russell James
Russell James's Avatar
That's good for the auto. For the M6, Royal Purple has worked the best for me.
Old 04-13-2010, 05:35 PM   #8
DarricSS
DarricSS's Avatar
Sorry i have no idea on what works well or is suggested for the Auto V6.
Old 04-16-2010, 01:37 PM   #9
BWood
BWood's Avatar
Drives: 2010 Camaro 2SS/RS M6
Just put M1 Syn. in tranny. A whole lot better but still notchy. I think I'll try the RP tomorrow and see if that's any better.
BWood is offline   Reply With Quote
Old 04-16-2010, 11:10 PM   #10
camarorick
camarorick's Avatar
Drives: .
Please let us know your results.... I used the M1 Syn too, and it still was a little notchy.... If the RP performs better, I'll give that a go
camarorick is offline   Reply With Quote
Old 04-17-2010, 04:50 PM   #11
BWood
BWood's Avatar
Well, I went all over the place and I could only find 2 quarts of Syncromax. DAMN!! Pep Boys said that they should be getting more in on Thursday. I'm gonna keep callin' around but I have a bad feeling that I'm just gonna have to wait!
Old 04-17-2010, 07:49 PM   #12
BWood
BWood's Avatar
O.K. I just called a little hole in the wall 25 miles away and they have the 3 quarts that I need. I will be doing this tomorrow and will let you guys know how it goes. For all of my effort, I hope that the RP will do the trick. Talk to ya tomorrow!
Old 04-17-2010, 09:23 PM   #13
BWood
BWood's Avatar
Manual V6: Gear oil (75w90)
Auto V6 : Dex VI
Manual V8: ATF Dex III
Auto V8 : Dex VI
Hope this helps!
Old 04-17-2010, 11:45 PM   #14
duder4thgen
Drives: Bird
GM's Dextron VI is synthetic, I doubt there would be too much to gain from buying Mobil.
duder4thgen is offline   Reply With Quote
DIY Manual Trans fluid change (pics) FFPM73 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 25 04-15-2012 10:15 PM
Phoenix T/A - New Trans Am concept based on 2010 Camaro 2SSRS@Gen5diy 5th Gen Camaro SS LS LT General Discussions 152 07-13-2010 07:32 AM
DOT 3 Clutch/Brake Fluid Recommendations MickGIS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 04-16-2010 05:54 AM
Changed the Diff and M6 trans fluid today... FirstLSK Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 04-15-2010 08:21 AM
LS3 manual trans fluid change - less noise, etc? TommyTSquared V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 33 03-14-2010 06:05 PM
