11-23-2015, 08:44 AM | #1 |
Drives: 2012 Camaro lt RS Join Date: Dec 2013
Want to put the OEM 18s on my SS/ Which Spacers??
OK so i had a 2012 camaro 1LT RS. I live in NY so winters can get bad at times. I decided to get a set of OEM 18" wheels with the all seasons. It seemed to do the trick. However i just upgraded to a 2015 SS and from what im hearing those 18"s will not fit over the Brembos. So my only option now is to get wheel spacers. I also herd people have had to shave the original studs. Im just curious if anyones had the same issue. What spacers should i go with and any others tips for getting these wheels on my SS. Thanks!
11-23-2015, 10:10 AM | #2 |
Not sure exactly what the fitment would be, but I know that you can either swap out your brake pads with the roller skates on them or cut them off. I have a friend that removed his for 18"s and it worked fine. He hasn't had the squeak issue so far..
In my state "adapters" are legal, but spacers are not. Ironically, I saw spacers on the shelf at O'reilley yesterday. I would avoid the spacers personally, they can cause lug nut fitment problems. |
11-23-2015, 10:39 AM | #3 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
Myself I would never consider wheel spacers. Buy a second set of stock SS size wheels and have winter tires mounted on them. Then just switch them for the season. Safe and secure.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
