02-28-2013, 08:54 PM | #1 |
Drives: 2011 2ss blk on blk convertible Join Date: Aug 2012
how much for cradle bushins install?
How much have you guys $pent on having a reputable shop installing the cradle bushings?
Just trying to get an idea. ... thanks |
03-01-2013, 01:56 PM | #2 |
No one? Even ball park....I got a quote and I thought it was way high, and I want to do it just wanna make sure I don't get burn....1g just labor is that about right or no?
03-01-2013, 02:18 PM | #3 |
Not sure. I'm going to be doing mine in the spring. It's definitely an involved process. I'm basically removing half my rear anyways so I figured I might as well rip the whole thing out.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
03-01-2013, 02:51 PM | #4 |
$1K just for labor is outrageous. It took me about 1.5 hours to remove the rear cradle using jackstands. Cut out the old bushings and remove from subframe and replace 2 - 3 hours and then re-install the cradle, I would probably put that number between $600 or less at $100/hr shop rate...I don't know that sounds high. This was not on a lift...I think with a lift the R&R of the cradle would be quicker for sure. I don't know what the shop rates are where you are at?
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
03-01-2013, 03:56 PM | #5 | |
03-01-2013, 03:57 PM | #6 |
Bayou City Muscle Cars
Drives: 2013 2SS Dusk Edition Join Date: Jan 2013
yeh gonna need to do this myself very soon. no facilities to do at home.
so will be paying as well. need springs and the bushes and sways :(
Lethal Racing Stage V PER 418ci Forged LS3 530/520 SAE |
03-01-2013, 04:07 PM | #7 |
Drives: cars Join Date: May 2011
A shop that has the right tool for removal can be done in a couple hours max. The rear doesn't need to come out, just lower the pumpkin while protecting the axle boots where they rest on the frame when lowered.
03-01-2013, 04:15 PM | #8 |
lll
Drives: 2010 camaro ss L99 Join Date: Jan 2013
i wouldnt pay $1000 dollars to have that done. thats for sure haha
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ APPEARANCE COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING |
03-02-2013, 06:10 AM | #9 | |
I do most of the work myself and have most of the tools to do the work right also, just don't have a lift to make things a little faster. $1K is high for that job.
03-06-2013, 07:15 PM | #10 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
Your in SoCal, call Haddad's, tell him I sent you. He does alot of Camaro's.
URR2SLO - If you're not going fast enough, get out the way......
03-06-2013, 08:28 PM | #11 | |
Drives: cts-v Join Date: Dec 2011
Come on Synner, you usually pay better attention than that! Not diff bushings, Cradle bushings. (I will give you the fact that it is in the rear end section, and not the suspension section) The cradle will need to come out, or atleast get dropped a good bit to get the old bushings out. A shop that is familiar with the job should be able to have it done within 4 hrs or so, especially if you are only doing cradle bushings.
03-07-2013, 08:10 AM | #12 |
Drives: 2010 camaro ss Join Date: Nov 2012
4 hours of labor is a good deal/ id expect 6 at most shops. I can do them in about 1.5 hrs, but have lots of practice
03-07-2013, 08:21 AM | #13 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
App $300-$400.
03-07-2013, 12:47 PM | #14 |
V's Automotive in orange can do it.
Tell him I sent You from hillbank and hell give you a damn good price. 7146542708
Wilwood 6 Pistons -Magnaflow X-Cat back - CDC Havoc Styling - TSW Wheels - Roadwire Custom Green Leather Interior - Hotchkis Race Suspension - Whiteline Flatout - KW V3 Suspension - 3M Wraps - Toyo Tires - IPF Supercharger - Vortech V3 - Airaid Filters
