02-11-2014, 09:58 PM | #1 |
Noob Header/Exhaust Question
If I get a Flowmaster American Thunder Axle back set up, and then want to add headers down the line. Will that exhaust be compatible? Or will it have to be removed at that point?
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
02-11-2014, 10:17 PM | #2 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
The axle back will work fine, axle back means you'll be leaving everything up to the cats stock. So you will need to make sure the headers you get will bolt up to your stock cat back system which is 2.5".
02-11-2014, 10:22 PM | #3 |
Smoked by a GIRL
What about a Catback system?
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
02-11-2014, 10:32 PM | #4 |
Ah okay. So at that point if I want kooks 1 7/8 I can just add from axle down another new piece
Sent from my iPhone using Tapatalk 2
02-11-2014, 11:50 PM | #5 | |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
02-12-2014, 07:20 AM | #6 |
Drives: E92 BMW M3 Join Date: Oct 2012
When you buy headers, just make sure you are buying 'factory' connection so it bolts right up to your factory midpipe(between cats and axle-back).
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
02-12-2014, 12:25 PM | #7 |
Drives: 2013 1LE camaro Join Date: Apr 2013
If you go kooks be sure to get the part number 6511-OEMC that'll bolt up to you factory exhaust, meaning the cats will be 3" on the inlet side and necking down to 2.5 to the outlet side leading to the flows..
Sent from the side view mirror.. While watching a ruststang fall back.. Ultimately just giving up |
02-12-2014, 03:42 PM | #8 |
Everything will connect just as it does now as long as you go with a factory style connection. Let me know if you have any questions and I'll be happy to help you further.
Best regards, Tyler 888-308-6007 |
02-12-2014, 03:48 PM | #9 |
Drives: 2010 SS, (ARH/Farks 8sec car) Join Date: Jul 2013
Give us a call.
We have 3 different Camaro5 Long Tube header systems in 1 7/8" or 2". We ship dozens each week. |
02-12-2014, 10:56 PM | #10 |
Drives: 96SS Join Date: May 2009
Do your self a favor and PLEASE dont buy Flowmaster.... We have seen as much as a 30rwhp LOSS from flowmasters.
02-13-2014, 08:20 AM | #11 | |
Drives: 2011 Black LS3 (Night Crawler) Join Date: Oct 2013
I would love to see a dyno chart that you lost 30 whp from installing flow-master axel backs when that adds no power just a nice rumble and some drone.... |
02-13-2014, 08:23 AM | #12 | ||
+1 for JDP great and fast shipping !! and ive had flow-master american thunder cat back on my L99 with kooks 1 7/8 bolted up fine just make sure when you buy headers that they can connect to the stock exhaust and they work perfect I have some used ones lying there that im not using on my LS3 theyll go for cheap once i box them up |
02-13-2014, 01:02 PM | #13 | |
02-13-2014, 06:15 PM | #14 |
If anyone is local to me I would be MORE than happy to install it for free and GLADLY show them.... Its happened MORE than one time.
