12-07-2010, 12:36 PM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2010
LS2 Edit vs Other Tuning Software
I don't often see many people who use LS2 edit to tune the Camaro. I'm assuming there is a good reason for that but I don't really know much about after market tuning software.
How does it compare to other tuning packages like HP Tuners or EFI Live? Does it just not have access to the number of tables the others do or is it just less user friendly? Can you get the same "quality" of tune with LS2 Edit vs the others?
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
12-07-2010, 12:39 PM | #2 |
Drives: 1999 Trans Am Join Date: Jul 2009
LS2 edit fell behind the times on tuning.I use to use it in 95/96 or so. Tried EFI live and never looked back.
12-07-2010, 09:35 PM | #3 |
Do you know if it allows you the same options as the other systems? I'm guessing not if you haven't used it for 15 or so years.
L99 - 440 RWHP
12-07-2010, 10:52 PM | #4 |
Sorry,getting old and losing years... LOL 05/06. Truthfully I forget alot of stuff about it. I know the logging sucked, changes were alot less than the other tuners and it locks the computer when you use it. Nevermind if you lose connection the car computer was junk and you had to bring the car to the dealer to be reflashed.
12-08-2010, 12:35 PM | #5 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
It was really bad. Go with EFILive. It has the best logging and on of the top two tuning packages. I think they are number 1 but I have been using them for years.
I think I stopped using edit in 2005. It is more DOS based. Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
12-08-2010, 01:52 PM | #6 |
I'm about 99% sure my car was tuned with LS2 Edit. Would I see much of a difference (in anything- performance, MPG, shifting quality, etc) getting it re-tuned with a different software package?
I have an L99 with a cam and LS3 conversion bits, LT headers, exhaust and an intake.
L99 - 440 RWHP
12-08-2010, 03:06 PM | #7 | |
The Hof
Drives: 2010 IOM Camaro 2SS/RS Join Date: Jan 2010
12-08-2010, 04:15 PM | #8 |
No new mods since the last tune. Just didn't know if LS2 Edit was leaving significant abilities on the table in any of those areas I mentioned above. I have faith in the tuner, I'm just not sure about the software package used.
L99 - 440 RWHP
12-09-2010, 08:46 AM | #9 | |
This is Totally Wrong IMO, and should Be Illegal. It is Your computer You should have access to it. Ted.
www.jannettyracing.com
12-16-2010, 10:39 AM | #10 | ||
Drives: GM anything Join Date: Sep 2009
I'm 100% against it too. There are multiple approaches to unlocking though; both hardware and software. The hardware approach is not as easy as it is for GenIII controllers. Once the flash chip is off, the seed and key are ripe... At the end of the day, it's often more cost effective to replace the controller. I have also seen some PCM's that were 'locked' with Edit, but they could be flashed right over (full write) right through the OBDII port, so it's always worth trying. |
12-16-2010, 02:13 PM | #11 |
L99 - 440 RWHP
03-12-2011, 09:17 AM | #12 |
Drives: 2011 L99 2SSRS Stock Join Date: Mar 2011
Tuning software for an L99
03-12-2011, 10:24 AM | #13 |
Primarily SCT and also HPtuners for in house only.
03-13-2011, 08:12 PM | #14 | |
Bill
Similar Threads | ||||
What tuning Software do you use?? | BowlingSS | Tuning / Diagnostics -- engine and transmission | 28 | 08-20-2012 07:29 PM |
Tuning for Dummies.... | allmotor | Tuning / Diagnostics -- engine and transmission | 8 | 08-08-2010 11:22 AM |
Superchips now offering multi vin apps and more. See inside for more details! | Scott@Superchips | Tuning / Diagnostics -- engine and transmission | 11 | 04-26-2010 06:46 PM |
