Old 12-07-2010, 11:43 PM   #1
2010 BADSS
2010 BADSS's Avatar
Drives: 2010 2SS/RS IOM
Driveshaft Shop 9inch conversion in LPE650
I am writing this install thread on behalf of C5 member rs-ss2 (AKA my hubby) due to time constraints on his part. This install is the Driveshaft Shop's 9inch conversion kit which we fitted with a Moser truetrac limited slip posi and 3.90 gear.
This install was done over the course of 2 weekends, as there was no rush to get it done.
First step was to remove the exhaust, heat shields, and the stock driveshaft.
Name:  D's rear1.JPG
Name:  D's rear2.JPG
Name:  D's rear3.JPG
Name:  D's rear4.JPG
Name:  D's rear5.jpg
Next, took off the wheels rotors, and removed the axle nut. It wa 34mm for the 1200 HP DSS half shafts that were on there. To remove the axle nut you need to set the e-brake and may need a cheater bar because it's really torqued on tight.
Then, disconnect the upper control arm, toe rods, trailing arm, and lower shock mount from the LCA.
Name:  D's rear6.JPG
Then pop the half shafts loose from the differential by using a large screwdriver as a wedge between the half shaft and the side of the differential. There is a clip inside that will pop loose by doing this.
Name:  D's rear7.JPG
Name:  D's rear8.JPG
We used a transmission jack to support the diff and removed it.
Name:  D's rear9.JPG
The next step is to assemble the DSS housing, gasket, and center section.
The center section came with studs and nuts holding the pinion support in place. These studs were removed and replaced with the DSS allen head bolts which are longer, so the bush mounting bracket and spacer (if required) can be put into position.
Our center section is the Moser nodular center section with an aluminum pinion support. This pinion support is thicker, so the spacer wasn't needed. It is included in the kit, since some center sections are thinner, such as those with a steel pinion support, and the spacer is required with these. If the spacer is required, it should be placed behind the bracket that is mounted to the pinion support. Here are pics of ours assembled.
Name:  D's rear10.JPG
Name:  D's rear11.JPG
Now everything has been removed, but before the new differential can go in, some modifications were needed. Because of it's larger size, the pumpkin would not fit. This is what was required for ours because we used the moser nodular center section. This picture shows before modification where the relief is needed. The wiring harness also needed to be relocated higher.
Name:  D's rear12.JPG
Here are where the cuts were made.
Name:  D's rear13.JPG
Here's how it looks after it was painted.
Name:  D's rear14.JPG
Here is where the relief was needed on the nodular ribbing.
Name:  D's rear15.JPG
This picture show the clearance now that it's in.
Name:  D's rear16.JPG
*Note* If a factory nodular housing from ford is used, no modifications are needed.
Now it is just a matter of putting in the new 9inch parts. The differential bushing that comes with the DSS kit has a slightly larger diameter hole, so the stock bolt had some play. So we bought the same length in a 9/16th inch bolt.
Name:  D's rear17.JPG
Name:  D's rear18.JPG
You also have to enlarge the hole it mounts to slightly.
Name:  D's rear19.JPG
Name:  D's rear20.JPG
Next, bolted the differential in place and made sure the driveshaft lined up ok. Then line up the splines of the half shafts and insert them into the differential until they seat completely. The half shafts on this kit are held in with 4 allen bolts on each side instead of the clip on the old half shafts, however there is very limited access to tighten these bolts. There is an access slot to the bolt which you must turn the axle to line up with each bolt. We also had to cut an allen wrench because of limited overhead access.
Name:  D's rear21.JPG
Name:  D's rear22.JPG
This kit is extremely well thought out. Also, Driveshaft shop and Lingenfelter (where we ordered our kits) are top notch and extremely helpful. After the test drive, I must say the 3.90 gear feels VERY PEPPY!!! We're putting one in mine over the next couple weeks. I'll post some torque specs tomorrow. Now for some final pictures.
Name:  D's rear23.JPG
Name:  D's rear24.JPG
Name:  D's rear 25.JPG
REAR SUSPENSION TORQUE SPECS
4 Strut Mount to Body Bolts 43lbft
Strut to Strut Mount Nut 33lbft
Strut to lower Control Arm 59lbft 120 degrees
Lower Control Arm Inner Bushing at Adjuster 85LBFT
Lower Control Arm at Knuckle Assembly 30lbft 120 degrees
Upper Control Arm Rear Bolt to Bushing 37lbft 120 degrees
Upper Control Arm Rear Bushing Bracket Bolts 59lbft 120 degrees
Upper Control Arm Pivot Joint 59lbft 120 degrees
Upper Control Arm to Knuckle Assembly 44LBFT 90 degrees
Toe Link inner to Subframe Adjuster 85LBFT
Toe Link to Knuckle Assembly Bolt 103 lbft
Trailing Arm to Subframe Assembly (Inner) 74lbft
Trailing Arm to Knuckle Asembly 30lbft 120 degrees
Front Cradle(Subframe) Bolts to Body 74lbft 120 degrees
Rear Cradle (Subframe) Bolts to Body 74lbft 120 degrees
Front Differential Bushings 59lbft
Rear Differential bushings 59lbft
Driveshaft to Differential 85LBFT
Caliper Bracket to Knuckle Assembly (L99, LS3) 30lbft 90 degrees
Caliper Bracket to Knuckle Assembly (LLT) 30lbft 90 degrees
Rear Sway Bar End link Nuts 36lbft
Sway bar Bushing Bracket bolts 16lbft
Nut for CV shaft to Knuckle...... 199lbft/270nm
Aluminum disc to drive shaft 54ft/lbs
Aluminum disc to transmission output shaft 70ft/lbs use loctite
Drive shaft u bolts to pinion 54 ft/lbs
LPE 650 BHP package
Dual disc clutch set
Borla catback exhaust-S type
DSS 9" rear with 3.90 gear
Pfadt suspension/Hotchkiss chassis brace
Forgeline Wheels VR3S/Nitto tires
Beware of the LPE Sisterhood
2010 BADSS is offline   Reply With Quote
Old 12-08-2010, 01:51 AM   #2
Ivan @ Southwest Speed
Very Well Done!!!
Woah. I'm impressed. Looks like a little finessing and it went in ok. I'll be chowing popcorn ferociously to hear the "street verdict" on the gear choice.
I'm hoping that you guys are going to be geeked with it as there are a bunch of folks wanting to know whether to go this way or 4.xx or ??
Great pictures and detail. I'm ready next!
Thank you for posting!
Ivan
Old 12-08-2010, 06:15 AM   #3
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
Thanks, 2010!! Very thought out and descriptive writting, with the perfect pics!! You have saved me a lot of time when I have to tackle the job myself. Now just sneak over to the strip and give us a drop in the 'ol 1/4 mile run.
Is there going to be another track day for you to test her out?
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 12-08-2010, 07:00 AM   #4
55Designs
Drives: 2010
This is the best review and install posted for anyone considering the upgrade. Good Job. By the way do the exhaust pipes hit the case by chance? the last photo they look close and I am wondering if you had to heat and drop the hanger a but for clearance.
let us know how it all works.
55Designs is offline   Reply With Quote
Old 12-08-2010, 07:32 AM   #5
600hp-lpe
Drives: 2010
Nice writeup Diana!
thanks for the tips on what you modified/changed.
Will make it easier to do mine when I am ready over the winter..
600hp-lpe is offline   Reply With Quote
Old 12-08-2010, 09:04 AM   #6
RS-SS2
RS-SS2's Avatar
Drives: 2010 Camaro, 09 mini, 01 3500
There is actually plenty of clearance in the diff area, however the bearing bracket area for the drive shaft hangs down a bit more than the stock piece. The DSS bearing bracket is a stout piece compared to the stock one. The only thing I had to do there was rotate the exhaust pipes downward 1/8th of an inch at the cat connection and mould the tinfoil heat shield for exhaust clearance.
RS-SS2 is offline   Reply With Quote
Old 12-08-2010, 09:27 AM   #7
2010 BADSS
2010 BADSS's Avatar
Here is another angle showing the exhaust clearance at the diff.
Name:  D's rear1.JPG
LPE 650 BHP package
Old 12-08-2010, 09:52 AM   #8
2010 BADSS
2010 BADSS's Avatar
Originally Posted by Ivan @ Southwest Speed View Post
Very Well Done!!!
Ivan
Thanks Ivan, after driving rs's, I'm glad we didn't pick the 4.11's I think the 3.90 is going to be perfect.
The 1/4 mile is closed till spring, and I think my car will be undergoing surgery for the next road course day Dec 18th. I doubt rs will let me take his.:( I'm just lucky he let me test drive it the other day.
LPE 650 BHP package
Old 12-08-2010, 05:08 PM   #9
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
Great post and excellent pictures, you did better than we did with them. i just wish it was a little warmer so you could take a good run with it. thanks for taking the time to show the install so clearly.
Frank
Driveshaftshop is offline   Reply With Quote
Old 12-08-2010, 06:48 PM   #10
2010 BADSS
2010 BADSS's Avatar
Frank
You're welcome, and thank you for all your information, help, and putting together this awesome kit! My car will be next, and then I can track it with confidence knowing that my driveshaft and rear will be able to handle the horsepower.
LPE 650 BHP package
Old 12-10-2010, 06:10 PM   #11
Driveshaftshop
Were at PRI displaying and i dident realize how many people dident know the kit comes complete with the Diff housing-mounting hardware-Axles-Driveshaft. most only seem to think its was just the housing. this afternoon there was actually a line of people waiting to look at.....
Old 12-11-2010, 08:28 AM   #12
RS-SS2
RS-SS2's Avatar
Frank
Frank, your welcome. I do wish the track was still open so we could break them in.
Old 12-11-2010, 08:31 AM   #13
RS-SS2
RS-SS2's Avatar
Are most people looking at the conversion kit or the main shaft?
I'm looking forward to getting the main shaft as well when testing is complete. Should make the car just about bullet proof then.
Old 12-11-2010, 09:42 AM   #14
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
Looks like she is very tight in there but great job!!!! Thanks for the pics and info!!!
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
more pictures, torque specs
F/S Driveshaft Shop SS Axles jmlozano7 Transmission / Driveline 20 11-15-2010 04:12 PM
Hot Deal. For Sale: 1400 Hp Axles By The DriveShaft Shop fastfaster Transmission / Driveline 10 11-11-2010 08:38 AM
"Transformers Camaro" Transforms The DriveShaft Shop 1000hp Axles To Metal Shavings fastfaster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 41 09-30-2010 09:15 AM
Body Shop Failure Dack 5th Gen Camaro SS LS LT General Discussions 50 09-27-2010 10:50 AM
NEW Driveshaft shop High output axles! IPS Brandon V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 09-19-2009 02:38 PM
