01-12-2011, 06:12 PM | #1 |
Drives: Camaro 2LT/RS IBM Join Date: Nov 2009
CAI Inc VS Roto Fab
I am stuck between the two. Which one performs the best? Also not that I plan on adding the Or sport ram air Hood later on down the road so I will need to be able to incorporate that as well. Price is a big factor as well.
01-13-2011, 12:45 PM | #2 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Well you know who my vote is for, but in all seriousness we have a lot of happy V6 customers on this forum. Our V6 produces an avg peak HP of 15 (see the Janetty tests thread for full details)
If you are reading this and you have a CAI Inc. Intake on your V6 help this guy out!! Thanks!! |
01-13-2011, 02:57 PM | #3 |
OKCamaros
Drives: 4 banger Diesel Join Date: Mar 2010
ADM Intake FTW!!!
01-13-2011, 03:37 PM | #4 |
Drives: '10 1LT/RS Join Date: Apr 2010
I'm on the fence between these two as well. I have some questions about these two particular intakes that might help you make a decision, when they get answered.
As far as adding a functional ram air style hood, both should work. Obviously the Roto-Fab will work, but Ive also seen a member on C5 with a CAI with the clear plexi-glass removed and added rubber to the top of the intake box to seal to the hood. Roto-Fab is cheaper (by about $100), but the CAI has a ceramic coated intake tube and insulated filter shroud to keep inlet temps down. To me, the $100 difference is about equal to the added insulation and ceramic coating. They come out pretty much even in my books for getting what you pay for. What I would like to know about the two intakes is this: Can someone explain the "Fuel Trims" section in the Janetty spread sheet? What is + vs - ? and why are the trims so high for the CAI? What does this affect? Were the Roto-Fab dyno #s (about +15hp) found with the hood open or closed? This is a big question since that large top opening will seal shut when the hood is closed. You would figure the Roto-Fab would make better #s with the hood open, so this is an answer I'd like before pulling the trigger on one. |
01-13-2011, 04:16 PM | #5 | |
Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
In reference to the heat transfer properties, our inlet elbow and MAF housing are molded cross-link polyethylene about .200" thick. The thicker plastic will transfer heat at a slower rate than most other materials. Our air box is not insulated, but does provide a very functional barrier against radiator and engine heat. Our inlet temps run very close to ambient when driving. When sitting idle the temps will rise, but not signicantly. The long term fuel trims are fuel adjustments made by your engine management system based on what the oxygen sensors are seeing in the exhaust. Let's monitor a "chunk of air"...First, your air is metered by your MAF sensor and "X" amount of fuel is added for this incoming air. The air/fuel mixture is burnt and enters the exhaust. Your oxyen sensor monitors this exhaust for rich or lean conditions. If the reading shows lean, fuel is added based on a percentage until you aren't lean. Short term fuel trims operate in a narrow range. If short term can't correct the lean condition, 1% long term fuel trim is added and the short terms try to work in their small range again. If the short terms can correct the condition now, then you would be operation on a +1 long term fuel trim. If not, then you would go to 2% long term, the short terms continue in that range and so on. Conversely, oxygen sensors see a rich condition they take away fuel leaving you with a negative long term fuel trim. I'm no expert on tuning, but I hope that helps you have a better understanding of long term fuel trims and how they adjust. The V6 Roto-fab intake runs within about 1% of stock on the car we did our testing on. This is something we are refining with our V8 kit as well for better performance right out of the box. |
01-13-2011, 04:17 PM | #6 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
01-13-2011, 04:21 PM | #7 |
OKCamaros
01-13-2011, 08:16 PM | #8 | |
Drives: 2lt Red jewel vin#6632 Join Date: Apr 2009
01-13-2011, 09:04 PM | #9 | |
I assume the trims for CAI in Janetty's test were high +ve numbers due to low intake temps leaning it out, and thus the engine adding fuel to accommodate. Is this not the best way to make more power? More air + more fuel? If the Roto-Fab trim numbers were the same as stock, does that mean the same amount of air flow into the engine (since no fuel had to be added)? |
01-14-2011, 07:09 AM | #10 | |
You can make more power because still get the advantage of our better flowing components such as our smooth, large radius inlet elbow, large radius MAF housing entry, larger and better flowing filter and large air box which allows more air in. |
01-14-2011, 10:23 AM | #11 |
01-14-2011, 01:07 PM | #12 |
Drives: '12 Toyota Tacoma Dbl Join Date: Sep 2009
Driving style and mods determine your mpg.....as you see in my signature what mods I have I get about 29mpg w/ 87 and 31mpg w/ 93.
STANDING 1/4MI: 13.948@99.87 6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK) |
01-14-2011, 03:35 PM | #13 | |
Can both of you pm me with pricing shipped to ON, Canada? (Roto-Fab, I might consider an orange painted filter housing). Thanks in advance to both of you! |
01-14-2011, 03:42 PM | #14 |
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
Roto fab air intake | paslag | Forced Induction - V8 | 34 | 01-05-2011 08:26 PM |
LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
