06-17-2011, 03:42 PM | #1 |
Banned
Drives: Car Join Date: Jan 2010
FACTORY GFX
I got my factory ground effects kit installed last June. I installed in two phases. I got my rocker panels installed no issues. I then went back and got my front splitter and my rear diffuser installed shortly after that. My front splitter has been the biggest pain. Less than a week after I got the splitter installed it started to fall off on both sides. So they stuck more double sided tape on it. That lasted awhile till one side started to sag so they installed two hex nuts. This past week my double sided tape gave out again. I took my car back to the dealer today to show them what's going on. They are offering to put silcone bead on the side that is falling? They need my camaro for a few hours so the stuff will dry. They are offering me a rental car on Thursday if I drop my camaro off. My question is how many people have troubles with your front splitter falling off?
06-19-2011, 04:58 PM | #2 |
okcamaros.com
Where did you purchase your GFX from? The front splitter use to fall off a lot when they first started producing the GFX, but they made a update to the mounting/brackets they place on the splitter. Make sure you received the updated front splitter.
06-19-2011, 05:17 PM | #3 |
Banned
I bought my gfx thru gmpartshouse.com I don't think it was a flaw in the kit. The directions stated let the double sided tape hold for at least 24 hours. Well my dealer let me borrow a car and I came back to pick it up 3 hours later and a week later the double sided tape gave out:( Then went back and got two layers of double sided tape. That worked for awhile. Then they put two little hex nuts one one each side. My right sided tape gave out again I live in Wisconsin where it gets 40 below zero in the winter but I don't drive my camaro in snow learned my lesson this past winter when I did a 360 degree spin and almost took a out a stop and go light I guess I will try this bead sealant now on Thursday. They are being nice enough to fix it again and they are even hooking me up with a car to use for the day It sounds like this time they are actually going to let my camaro sit for awhile to allow proper cure time??
06-20-2011, 08:45 AM | #4 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
All of this 3M tape stuff is turning out to be a problem. I installed mine and was meticulous. Changes in temperature and what the temp was when it was installed all sooner or later lead to failures even when installed according to instructions
06-20-2011, 09:06 AM | #5 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
I installed my OEM GFX two weeks ago my kit came with two plastic mounting brackets on for the driver and one for the passenger side that the front splitter will slid on top of and it has notches that lock it into place after then the red tape is removed and the bumper cover held in place with the 3MD tape. Here in Central Florida we have temps from 20 degrees to 100 degrees so far the past two weeks it’s been in the high 90’s for temps and my front splitter has held up great I would double check that the two plastic brackets were installed if not this is a problem.
Sean
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
06-20-2011, 09:27 AM | #6 |
There should be brackets riveted to your cars original body. The splitter hangs on that and would never sag. The 3m tape just keeps it secure. Take it to another dealer for a second opinion.
06-20-2011, 11:47 AM | #7 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
the dealer did not install it correctly, period. The front piece gets installed using bracket riveted on each corner then the fascia has to be removed from the car to drill the final rivet in the middle...then 3M double-sided tape is applied, front fascia carefully lined up and hung on the brackets, and 3M tape left to cure for 24 hours.
06-20-2011, 12:35 PM | #8 | |
Banned
06-20-2011, 01:10 PM | #9 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
Other than the fact that they don't fit perfectly (drivers side rear tire well is about 1/2" off), they're fine, no issues. But, did hear about earlier versions being very troublesome.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
06-20-2011, 01:28 PM | #10 |
ffcobra. I believe you are speaking to the design prior to the revised design. The new design would not fail due to the tape, and the fascia does not have to be removed. Now what does Stacey have...don't know
edit...original post says last June...therein lies the problem. The design has been revised. The rear GFX is still a problem though |
06-20-2011, 03:17 PM | #11 | |
06-20-2011, 03:28 PM | #12 |
Just Cruisin'
Drives: 2010 Synergy Camaro Join Date: Mar 2010
It is rivited but in the corners where it wraps around near the wheels is the location where the OP is referring to i believe. There are no rivits in this location and the splitter is held by double sided 3M tape. Mine has had this issue for months now. I stopped taking it to the dealer because the same issue keeps occuring.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels |
06-20-2011, 05:50 PM | #13 |
Its all about the U
Drives: 2010 SGM Join Date: Mar 2010
interesting, after much research with another splitter I was considering.. I am leaning towards GM's gfx .. the splitter in question.. but now if this splitter has these issues I have no idea what im going to do.....
UT- would you be able to send or post some more pics of your front and side body kit /// I know theres some in your garage but do you have any more?? Thanks .. goodluck OP
06-20-2011, 11:25 PM | #14 | |
Banned
Similar Threads | ||||
New member, hi! Question about the GFX package... | TheDayday | New Member Introductions | 5 | 04-24-2011 02:32 PM |
Stainless Works Factory Authorized Group Buy From APEX Motorsports! 15% OFF Retail!!! | Apex Motorsports | V8 Bolt-Ons & Tunes | 23 | 11-09-2010 11:17 AM |
Factory OEM cover fit over GFX front splitter? | FEN | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 1 | 10-31-2010 08:47 PM |
Painting GFX on the car? | My 5th | Cosmetics and Lighting Modification Discussions | 11 | 02-15-2010 01:50 PM |
Factory GFX or Aftermarket? | BlownSS | Cosmetics and Lighting Modification Discussions | 3 | 02-05-2010 08:44 PM |
