Old 07-14-2011, 09:44 PM   #1
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Questions on grille/license plate bracket removal
Whats the best way to remove the grille onan 01? I don't really want to do the whole pull really hard method. The reason I want to do this is because I wanted to take the front license plate bracket off, for a cleaner look. But when I go to unscrew the 3 bolts or whatever that holds it on all they do is spin forever. Any ideas would greatly help. After I get the license plate holder off I want to put some camaro insert there in its place. Thanks
Derek
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 07-14-2011, 09:56 PM   #2
dmginc
dmginc's Avatar
Drives: In Circles
check to see if there is a nut on the other side of the bolt. if not then use a flat head screw driver under the head of the bolt and pry on it a little as you loosen it and the threads should catch.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 07-14-2011, 10:01 PM   #3
Darkflow
Darkflow's Avatar
Drives: 2002 Chevrolet Camaro SS LE
So you just want to remove the license plate bracket off the stock grille? The pulling hard method might be your only option but im not sure. Either way though, your going to be left with holes in your grille thanks to the license plate bracket.
Have you thought about putting a billet grille on there? You can find them cheap on ebay.
2002 35th Anniv. Chevrolet Camaro SS# 4784 LE# 2117
Darkflow is offline   Reply With Quote
Old 07-14-2011, 10:07 PM   #4
insidethreat07
K ill have to check. I tried the screw driver under the head of the bolt and got nothing lol, thats why I'm kind of confused I guess lol.
Yea try, I was think about using like a hole filler, sanding it, and painting it. Not quite sure though want I want to do yet, trying to get some ideas
2001 Camaro V6
2016 Camaro 2SS
Old 07-14-2011, 10:10 PM   #5
Darkflow
Darkflow's Avatar
Post up pics if you can, i cant remember but i almost want to say that the license plate frame is held on to the grille by rivets.
Old 07-14-2011, 10:12 PM   #6
insidethreat07
I think you might be right about the rivets, I did tug on the license plate holder a little bit and and felt like there was rivets back there if that makes any sense
2001 Camaro V6
2016 Camaro 2SS
Old 07-14-2011, 10:20 PM   #7
Darkflow
Darkflow's Avatar
Yea that's what i thought. If your willing to fill the holes, sand & paint the grille. I would just pull it off and do that.
Old 07-14-2011, 10:23 PM   #8
insidethreat07
Yea I might just end up doing that . I like the billet grilles (+ they are cheap) but I think I would like the look of inserting the camaro lettering up front too. If I would do the billet grille, are they easy to install? As you can prob tell, I have never done this before lol
2001 Camaro V6
2016 Camaro 2SS
Old 07-15-2011, 04:19 PM   #9
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
The License plate bracket IS held on by rivets. I just installed my billet grille the other day, aside from the painful act of drilling into my baby it was not hard at all. took maybe 15 minutes tops.
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 07-15-2011, 05:27 PM   #10
insidethreat07
So lets say i wanted to keep the factory grille but take the license plate bracket off, I know I will have 3 holes in the grille. Now my question is what could I use to fill the holes in the plastic grille? I know it would have to be sanded down and repainted black. Thanks
2001 Camaro V6
2016 Camaro 2SS
Old 07-15-2011, 10:36 PM   #11
Bulldogwinters
SS #2431
I read a write-up on that somewhere.. thought it was ls1tech but I couldn't find it. I think it said just to fill it with some sort of filler putty then paint the entire bumper. the wholes aren't very big. My grille is laying around my garage somewhere still
EDIT:
Found that write-up
http://www.ls1.com/forums/showthread...k-Grill-Insert
Old 07-17-2011, 11:48 AM   #12
insidethreat07
K thatnks for the link, ill have to check it out
2001 Camaro V6
2016 Camaro 2SS
front license plate alternative? babyjulie83 Cosmetics and Lighting Modification Discussions 70 02-15-2016 07:55 PM
Front License Plate Bracket Options NOVAK Cosmetics and Lighting Modification Discussions 4 04-15-2011 10:27 PM
Front Plate bracket installed by mistake.. grrr Lurker67 5th Gen Camaro SS LS LT General Discussions 28 07-04-2010 06:42 AM
License Plate Covers / Removal ?? Jay_LHD3 2010 Camaro5 Fest (I) 4 03-25-2010 09:26 PM
Front License Plate Bracket blackZbandit 5th Gen Camaro SS LS LT General Discussions 76 08-17-2009 05:51 PM
