Old 09-20-2011, 03:38 PM   #1
Granatelli
Drives: 2SS Victory Red
Edelbrock Blower Question
I have a customer that is bringing in his 2011 SS that already has a stock Edelbrock blower on his stock motor. We are building him a stout long blower and I wanted to pulley it up (smaller blower pulley) how small can I go without slipping the 6 rib and what should be the belt length - please and thanks in advance
Granatelli is offline   Reply With Quote
Old 09-20-2011, 07:31 PM   #2
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
Right now I have the 2.75 pulley on my E-Force with the Goodyear belt part#GDY4061030 and no slipping at all.
Busy_Boi is offline   Reply With Quote
Old 09-21-2011, 03:20 PM   #3
Granatelli
Thanks - that is what I was looking for
Old 09-21-2011, 03:53 PM   #4
Mike@RMCR
Mike@RMCR's Avatar
Drives: Supercharged
I would also do the fuel line mod on the rails. Have seen alot of these superchargers run the rails dry, do to the way edelbrock runs them.
Mike@RMCR is offline   Reply With Quote
Old 09-21-2011, 04:17 PM   #5
Granatelli
I will look into that as well
Old 09-21-2011, 08:56 PM   #6
Busy_Boi
Busy_Boi's Avatar
Yes he is right about that and maybe some 72lbs injectors too.
Old 09-22-2011, 05:23 PM   #7
Granatelli
What inj does Edelbrock include in their kit
Old 09-22-2011, 06:51 PM   #8
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
They ship 52lb with the kit. Bosch 0280158187.
Bosch ZR1 52lb/hour with EV6 / USCAR Connector - Direct fit for LS9
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 09-22-2011, 06:54 PM   #9
coptzr
Resistance is futile
coptzr's Avatar
Drives: Anything thats fast
Running the 52's that came with the blower, they are ZR1 injectors, from what I have been told. I'm at 583 RWHP with stock pully and CTS-V dual pump and module. No issues at all.
Modifications (so far)
Edelbrock E-Force supercharger
JRE fuel system upgrade
Edelbrock CAI
VMS stage 2.5 cam kit
SLP LT's, no cats
NPP muffler's w/x-pipe
Tuned at Vector Motorsports
606 RWHP and 567 RWT
Black 1LE 10 spokes.
Hotchkis drop springs.
coptzr is offline   Reply With Quote
Old 09-22-2011, 07:39 PM   #10
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
At 540rwhp the 52sīs were "almost" max out (90-98% cycle) according to my tuner.
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 09-26-2011, 03:17 PM   #11
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
If you are going to a smaller pulley (increasing boost) with the e-force on a stock shortblock you better feed it and tune it right or bad things will happen...the questions being asked here tell me that your experience with this blower is limited. I'd call Ted Jannetty at JRE and get some "industry-advice" before you end up with a pissed-off customer with a trashed motor.
S-eatin-grin is offline   Reply With Quote
Old 09-26-2011, 04:49 PM   #12
Granatelli
I have no experience with the Edelbrock that is why I was asking I have a ton of experience with FI. As I owned Paxton Superchargers for 8 years and before that I worked there for 12 - So 20 years of Paxton, I raced Indy Car and owned a team back when it was CART and turbo'd. We also build many single and twin turbo kits for customers.
Edelbrock on a Gen 5 Camaro - not so much,
We are building this person a long block with great flowing heads and all the bottom end parts to safely support 800.
As for 52's. I understand and will monitor inj pres and flow. And for the record a 52 will support 756 crank HP at 60psi at .55 bsfc
This customer will be super happy with 600 rwhp so I should be safe
Old 09-26-2011, 05:38 PM   #13
SC2150
If you need we can machine in the "Gator Grip" anti-slip patteren. No real increased wear and makes a big difference. PM me for details.
Old 09-26-2011, 07:15 PM   #14
S-eatin-grin
I meant no offense and I guess I didn't quite get the part where you said you were replacing the stock internals. Sounds like it will be a beast and I will be curious to hear the results. I've been wondering what the strongest e-force build out there is to date on a gen 5 camaro?? maybe this will be the one
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 110 01-25-2019 04:23 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 07:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question for blower Guru's carguy Forced Induction - V8 15 04-16-2010 10:57 AM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
