03-11-2012, 04:30 PM | #1 |
Drives: '17 GT350 Join Date: Mar 2012
Oil Separator (Catch Can) from Moroso...
I was wondering if anyone here is using this particular type. Moroso has been in business for a long time.... They are much pricier than RX, however, the unit looks pretty good.
http://jreperformanceparts.com/gm/20...catch-can.html |
03-11-2012, 05:48 PM | #2 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
Looks too small IMO. I would rather have my can bigger so that it has more surface area to cool the gas to allow the vapors to condense.
03-11-2012, 09:21 PM | #3 |
I have it and like it.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir 1989 Silver 5.0 Mustang LX Coupe 1999 Pewter Tahoe LT 2011 Blue Camry SE |
03-11-2012, 10:07 PM | #4 |
Got to play with one at a trade show today. It looks great but I want to say I've heard mixed reviews on it. Then again I'm not to sure about catch cans in general but whatever makes us happy and doesn't negatively effect anything (besides our wallet ) can't be bad.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
03-11-2012, 11:15 PM | #5 |
Drives: Sofia: 2012 Chevy Camaro 2SS LS3 Join Date: Feb 2012
I decided on RX after reading some people on here do some testing with a glass in line filter and dissecting one of their cans. It's the best, performance wise, was the verdict.
I ordered last week and still haven't heard anything though, not a mesage, email, nada. I'm getting a little worried it won't get here before the car does (crosses fingers) P.S. The Moroso one looks slick though.
Interior: 2-tone gray interior, Blue Dome and trunk lights, L.A. Dodgers floor mats (to come: footwell lighting)
Exterior: Sunroof, custom painted gray stripes, vinyl Bowtie emblem decals, Holographic Transformer decals, white license plate LED lights Sounds: Stock highs, Alpine MRX-M100 amp mated to a 12" JL Audio W3 in a ******** Stealth enclosure Engine/Performance: Hurst Short Throw Shifter, Rx Catch Can painted IBM, (to come: JacFab CAI, muffler delete/Flowmasters) |
03-12-2012, 02:05 AM | #6 |
Drives: 2010 2SS/RS LS3 A6 Join Date: Mar 2011
Can someone tell me what a catch can does?
03-12-2012, 03:21 AM | #7 |
Here is a detailed explanation of it's principle...
An oil catch can is typically used in turbo/supercharger applications, or high-performance race applications where excessive blow-by (leakage past the piston rings) of air and fuel vapor occurs. This creates a positive pressure in the crankcase. Engine manufactures have placed a valve on the engine block which releases this pressure. This valve is known as a PCV (Positive Crankcase Ventilation) valve. During engine operation, blow-by gases, as well as oil mist from the rotating components of the engine, pass through the PCV valve and are routed back into the intake for the engine to burn off. However, some of the oil mist and other products settle along the engine intake and over time form a "gunk." The oil catch can collects the oil mist and condenses the fuel vapors while allowing "cleaner" gases to be passed back into the intake. Typically the blow-by gasses are passed through a wire mesh, which give the vapor droplets something to adhere to. Since the oil catch cans condense the vapor portion of the gasses, they will need to be drained periodically of all the oil, fuel and other contaminants. |
03-12-2012, 03:25 AM | #8 |
03-12-2012, 10:32 AM | #9 |
Been great. I got it because to many threads about RX and oil leaks, valves sticking and blowing out rear main seals.
03-12-2012, 11:21 AM | #10 |
Drives: 2011 SS RS Camaro Convertible-VR Join Date: Mar 2011
I went with the Elite, simple instructions and I believe will do the job!
03-12-2012, 02:29 PM | #11 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
The Moroso works much better if you remove the filter material from whatever side you use for the outlet. It hold oil at the outlet and lets a ton pull right through. Just remove the two smal allen screws that hold the filter media in the top portion and pull the steel wool out of the outlet side and it will trap far more than as it comes. Do a search on here for details on the testing (try for yourself, dont trust in anyone else) and you will see.
03-12-2012, 02:50 PM | #12 | |
03-13-2012, 06:50 PM | #13 |
Drives: 4 wheels Join Date: Oct 2011
i like moroso stuff,, they have a larger one which you may bennefit from
03-13-2012, 07:33 PM | #14 | |
No oil leaks caused (unless installed backwards). And one reported valve frozen by condensation in the winter....so please get your facts straight if your going to make a statement like that. If you would place a clear glass fuel filter between the can and your intake manifold you will seethe amount of oil pulling through...and thats fine if thats what you want, but please dont post lies about the RX can. |
Similar Threads | ||||
Can we use the catchcan made for the G8? | HaZe_X | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 05-05-2010 10:35 AM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
