Old 03-29-2012, 08:41 AM   #1
metaphysician
metaphysician's Avatar
Drives: 2SSRS CGM & Harley Crossbones
Injector and throttle body cleaning at the dealer...
I had my 2SS RS in for a Mobil1 oil and filter change. I'm at 34,xxx miles. I do not have any performance or fuel economy issues. Dealer recommended fuel injector and throttle body cleaning for $169.95. I'm thinking since I don't have any issues right now and that price seems a bit steep, should I pass? I declined for now. Thoughts?
metaphysician is offline   Reply With Quote
Old 03-29-2012, 09:47 AM   #2
Russell James
Russell James's Avatar
Pass.
That is practically criminal theft. Ask the service writer, let me guess.... your pay is commission based?
If you have been using good gas, and it is running perfect... no reason to clean the injectors.
Plus you wouldn't want to do it with a fresh oil change, it will wash gunk down into the fresh oil.
Very easy DIY, if you wanted to handle it yourself for < $10.
A week before your next oil change, put a bottle of cleaner with Techron in the tank. I've used Chevron with Techron, good stuff - comes in a black bottle at auto parts stores. It is the exact same stuff as sold at the GM dealer's parts dept. Floor it a couple times during that week. That will do a good top engine cleaning, and will clean the injectors. Your oil will be black.
When that tank of gas is gone, refill with new gas and change the oil. Pop the throttle body off, and wipe out any carbon on the backside of the throttle blade and body. That is a piece of cake, the gasket is even reusable, no coolant loss. Very easy DIY job in the garage.
That's why they try to push it on everybody in the service lane. Gravy, high profit margin work..... that you really don't need.
Ask them to look up the bulletin from GM on selling unnecessary flush and cleaning services. Basically it says - quit being thieves to customers that just come in for an oil change.
And look how well it works. A thief is a thief.
Old 03-29-2012, 10:13 AM   #3
metaphysician
Sounds about what I was thinking. Thanks for the information as well as the DIY solution.
Old 03-29-2012, 10:52 AM   #4
SC2150
A properly functioning catchcan will preventneeding the TB and uper induction cleaning period. Fuelinjectors follow russell'sadvice.
Loss of Air Conditioning - Reprogram Body Control Module MS3DALE Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 23 07-03-2012 12:52 PM
2011 ac recall question . 1JEWLDSSRS 5th Gen Camaro SS LS LT General Discussions 21 06-28-2011 12:24 PM
Help!!! - Paint issue not being resolved by a local dealer c0rsa180 5th Gen Camaro SS LS LT General Discussions 29 04-23-2010 12:20 AM
YOUR WARRANTY INFORMATION Kwaz1335 5th Gen Camaro SS LS LT General Discussions 2 11-02-2009 05:23 PM
Did you get an order # or any refernce for your pre-order? D1BADZ Camaro Price | Ordering | Tracking | Dealers Discussions 21 05-22-2009 05:39 PM
