Old 04-01-2012, 02:57 PM   #1
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Antifreeze
Quick question! What is the best type of antifreeze? I know DexCool! But diluted non diluted and what color orange or green? I need to top mine off! Just want to get the right kind!!!!!
csjcsj is offline   Reply With Quote
Old 04-01-2012, 03:20 PM   #2
Stealth6
Drives: '17 GT350
Stay with DexCool. Do not mix it with the green ( Ethylene Glycol ). Ethylene Glycol is chemical that is not compatible with DexCool. When mixed together they form a gel-like substance that stops coolant flow and consequently the engine can overheat.
Stealth6 is offline   Reply With Quote
Old 04-01-2012, 03:50 PM   #3
csjcsj
csjcsj's Avatar
Thanks, just curious!
Old 04-01-2012, 03:52 PM   #4
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
Orange/pink.
Southern Comfort is offline   Reply With Quote
Old 04-01-2012, 04:17 PM   #5
csjcsj
csjcsj's Avatar
Can or should you top it off with water???
Old 04-01-2012, 04:26 PM   #6
Stealth6
Drives: '17 GT350
Yes you can, however, to much water is not good either. Your coolant has a unique lubricant additive that is essential for the water pump bearing/seal.
Old 04-01-2012, 08:43 PM   #7
hunt
Drives: 10 SS 08 675 13 Stryker 10 S1000RR
Not if you buy the premade mix.
Never put up with something high maintenance, unless it's high performance.
hunt is offline   Reply With Quote
Old 04-02-2012, 05:26 PM   #8
Joed
Drives: Camaro 2SS RS Victory Red
If you use water, use only distilled water as regular tap water usually contains some mineral in it which is bad for your engine..
Joed is offline   Reply With Quote
Old 04-02-2012, 08:09 PM   #9
csjcsj
csjcsj's Avatar
I would have to do that anyways, if needed! I have well water! Just gonna get a jug of dexcool, to play it safe!
Old 04-03-2012, 03:42 PM   #10
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
How many gallons for a flush and refill of the radiator?
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 04-03-2012, 04:17 PM   #11
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Owners Manual........ Did you read it?
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 04-05-2012, 10:19 AM   #12
Snake Slayer
Actually I was hoping a gifted intellectual like yourself would perhaps provide a detailed explanation
It says 13.4 quarts for the capacity of the entire system. Conventional wisdom would say that a significant amount may remain in the block with just draining the radiator. I was mealy trying to get an accurate refill from someone who has done it.
Awaiting 2014 C7
What is the correct way to check antifreeze? nyrfan Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 07-17-2014 01:18 PM
Heet fuel line antifreeze. Part #28201 69 Rebel Canada 1 08-21-2010 07:45 PM
Royal Purple Antifreeze Additive olblue75 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 05-23-2010 11:09 AM
Antifreeze Slvr1SSA6 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 16 12-02-2009 09:28 PM
Antifreeze Xcessive 4th Generation Camaros 6 06-11-2008 03:45 PM
