09-17-2012, 06:14 PM | #1 |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
427 engine, what to expect......
So, my friend just finished his 427 engine with a TVS2300. According to the dyno pull, it's making 13psi and 621rwhp and 598torq. We think that the numbers are way low. What do you guys think? We need some feedback before going back to the original setup expectations.
Thanks!!!
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
09-17-2012, 06:29 PM | #2 |
Drives: 2011 Camaro Join Date: Mar 2011
You need 14 PSI
09-17-2012, 06:30 PM | #3 |
What type of dyno? makes a difference
09-17-2012, 06:35 PM | #4 |
Drives: cars Join Date: May 2011
Need a lot more info like compression ratio, fuel system, octane, injectors, AFR, etc.
09-17-2012, 07:04 PM | #5 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
I have heard that the 427 is not ideal for boost but I have see numbers way higher as well.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
09-17-2012, 07:04 PM | #6 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Supercharger might be running out of steam for a 427? Especially since its a 2.3L. Dont most 2.3's max out around 17-18 psi on a 376 ci?
09-17-2012, 07:09 PM | #7 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
09-17-2012, 07:10 PM | #8 |
Need like more info... if the ls3 was stroked to a 427 watch out as the sidewalls will be very thin..
09-17-2012, 07:11 PM | #9 | |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
09-17-2012, 07:12 PM | #10 | |
13 PSI into a well built 427 should get you at least 750RWHP. I am hoping to get 12 PSI out of my D1SC with my HKE built LSX 427 that was built for boost. I figure on about 800rwhp if i can get the 12 Lbs boost to the motor. Will know in a couple weeks. Erik is hand delivering the motor next week
09-17-2012, 07:32 PM | #11 | |
09-17-2012, 07:53 PM | #12 |
Drives: cts-v Join Date: Dec 2011
09-17-2012, 08:22 PM | #13 |
It's a manual, LG full exhaust, Nelson Engine 427, cam that's what I know. I will get more info and post.
09-17-2012, 08:30 PM | #14 | |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
