06-10-2009, 06:12 PM | #1 |
Drives: 2012 GT500 SVTPP 2010 Traverse LTZ Join Date: May 2009
402 Stroker LS3 with FI?
Any knowledgeable engine builders have any thoughts on having the LS3 stroked to 402 with a low compression forged internals FI build? Would this be beneficial? I admit I like the number due the heritage of the old 396 (402's) Camaros. What would be the benefit of this versus a forged build of the standard LS 3? Would there really be any benefit to this versus a standard forged LS3 or a LS 7 FI build. Just trying to get some ideas for my purchase next spring. Thanks in advance.
06-13-2009, 01:39 AM | #2 |
Drives: 1981 Chevy Celebrity Join Date: Mar 2009
I am not an expert builder, but the lower the compression ratio the more boost the motor can handle safely. Also The more air and fuel you push into the motor the more heat you are going to get from detonation. So in the end forged products would be better depending on what kind of power you are trying to attain. In regards to the LS7, the cylinder walls are thinner than the walls of the LS3, which makes it a more reliable motor for FI. Just my two cents. Good luck.
Similar Threads | ||||
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2009 06:02 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
Advice---Supercharged L99, S/C'd LS3 or LS9? | CamaroZR1 | Forced Induction - V8 | 25 | 09-25-2008 09:21 AM |
LS3 Specs, and Descriptions | Mr. Wyndham | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 11-06-2007 01:04 PM |
