Old 01-23-2013, 08:46 PM   #1
laditee
laditee's Avatar
Drives: 2010 Camaro 2SS
PSI
Hi guys and Gals I have a question and hope u all can help, yesterday i notice that my oil pressure needle on my gauges was all the way to the right pass the PSI area. It usually stays somewhere in the middle. Is this a bad thing, what does this mean? Please any advice would be appreciated...Thanks everyone
laditee is offline   Reply With Quote
Old 01-23-2013, 08:48 PM   #2
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
Means you need to take it to the dealer and have them run a diagnostic . Does it still have its powertrain warranty?
Frid is offline   Reply With Quote
Old 01-23-2013, 08:48 PM   #3
naSSty1
Drives: 2010 Camaro SS
Uhh, yeah that is not normal. If it was all the way pegged out than there is a problem some where.
naSSty1 is offline   Reply With Quote
Old 01-23-2013, 08:48 PM   #4
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
I would say the sending unit went out. When you turn on the key does the needle move?
IOM Black Diamond is offline   Reply With Quote
Old 01-23-2013, 08:51 PM   #5
laditee
laditee's Avatar
Not sure if I still have it if its 100,000 miles then yes I do...ill double check
Old 01-23-2013, 08:53 PM   #6
Frid
Frid's Avatar
I'd take it to the dealer then. What Black Diamond says may be true. But if it's constantly pegged, then drive it to the dealership asap. You don't want to run it with that much pressure going through the motor. You could damage a seal, likely the rear main.
Old 01-23-2013, 08:54 PM   #7
laditee
laditee's Avatar
When I turn the car on the needle go's all the way pass the PSI....it stays there as long as im driving but when I stop at a light it starts to rise then drops back pass it as i excelerate
Old 01-23-2013, 08:55 PM   #8
Frid
Frid's Avatar
Not understanding what you mean.....are you saying it is showing the needle to the left or right? If it's showing 0, then it could be the pump which is not good at all. If its all the right at 70 I think it is, then it could be what Black Diamond said.
Old 01-23-2013, 08:56 PM   #9
laditee
laditee's Avatar
Its showing all the way to the right
Old 01-23-2013, 08:58 PM   #10
Frid
Frid's Avatar
Ahh ok gotcha. I was confused on the last part of the post. If the dealer isn't too far, I would just take it there. You are still under warranty so it wouldn't cost you anything. Tell them what you are seeing. Could be something big or could just be the sensor. You never know.
Old 01-23-2013, 09:05 PM   #11
IOM Black Diamond
HT5 COTW 1/21/13
When you start the car it should sweep all of the way to the right then left, then to what oil psi. My car runs about 35psi at a idle. If it is reading max psi then coming back down when you stop something is wrong. I dont know if I would drive it until you find out whats wrong. You don't want to wipeout your motor.
Old 01-23-2013, 09:06 PM   #12
laditee
laditee's Avatar
Ok i sure will...but it happen yesterday on my way to work so ive been driving it yesterday and today do u think im pushing it
Old 01-23-2013, 09:08 PM   #13
Frid
Frid's Avatar
Yes. You don't want to drive it until you know what the problem is just like Black Diamond said.
Old 01-23-2013, 09:09 PM   #14
laditee
laditee's Avatar
Yeah thats what it usually does but since yesterday it reads maxx psi and stays there...it moves up just alittle when im stopped but only to the maxx line then drops back down pass the PSI
