06-02-2013, 07:34 PM | #1 |
Belt size for 3.1 pulley
I currently have the Maggie 2300 on my 2011 Camaro! I am running the 3.4 pulley on it and actually am not to sure what size belt is on it.
I just received the 3.1 pulley and I was wondering what size belt I should get, and what y'all's preference on brands of belts are? Thanks! |
06-02-2013, 08:26 PM | #2 |
Drives: 2006 Crownline Join Date: May 2012
Most likely you are running a 'Gates' belt. I think they make belts that 'Napa' puts their brand name on as well.
Gates has a list of it's size and part numbers here: http://www.gates.com/oreilly/PDFs/SizeListings.pdf If you change the pulley on your supercharger, you will also need to get a tune. Hope this helps. |
06-02-2013, 08:28 PM | #3 |
Also if you have the stock pulley setup, most likely, you have 6-ribs. So on the chart the K06xxxx is what you should focus on. K04xxxx is 4 rib......K08xxxx is 8-rib and so on.
