06-14-2013, 11:17 PM | #1 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Eforce 8 rib pulleys
Might be of interest.....
It was just brought to my attention that Innovators West now has 8 rib pulley on their site. http://www.innovatorswest.com/912-Blower-Pulley.html
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
06-15-2013, 10:56 AM | #2 |
Drives: 2010 2SS Join Date: Sep 2012
Awesome!! this will be my final upgrade on my motor until my bottom end fails
what fuel pump system do you run canuk?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
06-15-2013, 03:20 PM | #3 | |
I run a Z06 pump with a KB BAP and racetonix harness. I will upgrade one of these days but see no pressure drop for now.
06-15-2013, 03:23 PM | #4 |
well holy hell with that much HP/TQ maybe i will stick with my zl1/adm combo
06-19-2013, 11:42 AM | #5 |
Drives: 2SS Join Date: May 2009
Had this set up for awhile now, love it.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
06-19-2013, 11:54 AM | #6 |
Pics!!!!!
