08-24-2013, 03:40 PM | #1 |
Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
WTB: SS rotors
Looking for a nice low miles set of SS rotors in my area that someone has laying around because of an upgrade.
08-25-2013, 11:13 AM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2009
Where are you located in Indiana? I have a set with around 600 miles on them, I'm in southern in
08-25-2013, 11:24 AM | #3 |
I am near Marion and Gas city Indiana. How much you wanting for them?
08-25-2013, 02:56 PM | #4 |
pm sent
08-25-2013, 05:46 PM | #5 |
Sent one back. I want the rotors!! Thank you
08-25-2013, 05:53 PM | #6 |
Drives: 2011 RS Join Date: Apr 2011
What are SS rotors? The rotors that come with Brembo's??
08-25-2013, 07:31 PM | #7 |
08-26-2013, 02:02 AM | #8 | |
COTW [4/23/12]
Drives: Camaro Of The Week. Join Date: Aug 2011
and you're going to swap with your v6 calipers? if so, u need the whole setup.
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune | My Build Thread |
08-26-2013, 05:38 PM | #9 |
08-26-2013, 06:27 PM | #10 |
Drives: '12 2LT Convertible Join Date: Mar 2012
What are you doing about the F&R dust shields and the master cylinder? You also need new caliper mounting bolts.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
08-26-2013, 07:01 PM | #11 |
08-26-2013, 07:17 PM | #12 |
Here is a write up for the upgrade to Brembo brakes.
http://www.camaro5.com/forums/showthread.php?t=62282 |
08-27-2013, 09:34 AM | #13 |
Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
Stock v6 front lines will work also, but different banjo bolt thread pitch...rear lines dont work cause of the bend at the banjo bolt fitting blocks the mounting bolt (ss rear line is straight) rear banjo bolts are the same from v6 to v8...and like he said, just trim off some of the lip on rear dust shield...easy swap...i did all four in a couple hours
08-27-2013, 10:44 AM | #14 | |
