Old 11-23-2013, 12:23 PM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
Tuning JANNETTY RACING built Transformers for C-16
We have the JRE built Transformers car here for some more updates and tuning and decided it was time to move to a different fuel so we switched to C-16 from the MS-109
The results were Pretty impressive we picked up 105 RWHP.
This is a LPE 427 with JRE Cam 2 inch headers YSI supercharger ID-1000 injectors and an ATI Powerglide Transmission at 20 PSI boost.
Previously 1017 RWHP with a Manual Trans
Then 901 RWHP With the switch to the Powerglide ( autos without Lock up converter always show lower Power on the chassis dyno)
With the C-16 in the tank and a few strokes of the key board we are happy to report 1006 RWHP.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 11-23-2013, 02:31 PM   #2
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Boost only? What about on spray with the direct port?
VanquisherSS is offline   Reply With Quote
Old 11-23-2013, 03:07 PM   #3
Boost6924
Drives: 2SS/RS
Then 901 RWHP With the switch to the Powerglide ( autos always show lower
Very nice. May I ask what fuel system is in the car? I made 1100+ with MS-109 and ID 1000's @ 19psi, but after all bugs sorted out, my Aeromotive in tank pump is plain out of volume, fuel pressure is dropping on high loads.
Thanks for sharing quality comparison between the fuels.
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
Old 11-23-2013, 04:18 PM   #4
ayousef
ayousef's Avatar
Drives: 2013 ZL1
how much pressure are you loosing? no harm if you aren't loosing way too much pressure though. My car makes 21.5psi here in cold Dubai, on 93 octane pump gas, how? Static and Dynamic compression ratio, well and probably a missing link which I haven't figured out yet
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 11-23-2013, 05:26 PM   #5
Boost6924
Drives: 2SS/RS
It's loosing 15 psi at the top (above 6000rpm) of the pull on 4th gear.
Old 11-24-2013, 09:49 PM   #6
headless camaro
Drives: 2013 white auto
the transformers banana?
headless camaro is offline   Reply With Quote
Old 11-25-2013, 09:04 AM   #7
JANNETTYRACING
Just Boost, The dyno rollers are too slippery to measure the power with the Spay, I made a few hits on Sat and blew the slicks away.
My Dyno is now over 10 years old and the Knurl has worn Smooth.
I Am having Carbonite come in next Tuesday to Coat the Rollers to eliminate this issue.
This is one of the Few Fore Triple pump systems that were made along with a Custom ADM Triple MSD Voltage booster set up Andy made for us.
Nuclear Banana.
Old 11-25-2013, 09:53 AM   #8
Crawler
Crawler's Avatar
Drives: 12 2SS L99
I've almost always steered clear of oxiginated fuels on boost applications. Only exception being if I've run out of blower due to it being way undersized.
Always been a fan of high octane in race applications with spray or boost. MS-109's only place in my mind is in a non power adder application.
Way too big of a likelihood of melting something. Maybe its just my tuning abilities.
You have way more experience here than I do. Will you share your experiences with oxiginated fuels in big power adder applications?
Car nut for life.
Wes Snow-GM Employee
C6-LTs,Magnaflow,Halltech,Cam,Yank 3200,TranCooler
09 Hayabusa-Spiney thing in the exhaust 468RWHP
95 Dodge Cummins- 9.5 1/4 mile
Gone-12 2SS/RS SMD Built
Gone-C6 Procharged 416
Gone-07 CTS-V Procharged 427
Crawler is offline   Reply With Quote
Old 11-25-2013, 11:06 AM   #9
TROndrey
TROndrey's Avatar
Drives: 2010 IBM 1LT/RS
Nuclear Banana.
GO BANANA GO!!!
2010 Camaro 1LT/RS
Imperial Blue Metallic
K&N Typhoon CAI
MRT v2.0 Axle-Back
RX Performance Catch Can
TROndrey is offline   Reply With Quote
Old 11-25-2013, 11:11 AM   #10
JANNETTYRACING
We use oxygenated fuels for More Power over pump gas, and keep Oxygen sensors Happy, but anytime we are looking for more power there is more risk.
We do have to run them a 4-6% richer that we normally would.
For example we ran 10.4:1 with Oxygenated fuel and we run 11.5:1 on C-16 same set up.
Ted.
Old 11-25-2013, 12:00 PM   #11
Crawler
Crawler's Avatar
Drives: 12 2SS L99
Ted.
That follows what I've seen for a safety net. It just always left so much HP on the table.
Car nut for life.
Old 11-25-2013, 12:22 PM   #12
JANNETTYRACING
It really has more to do with the Stoich value 13.4 for VPms109 14.777 for C-16
Ted.
Old 11-25-2013, 01:14 PM   #13
white ZL1
Drives: none
So there's no difference. Appx .78 lambda on both fuels.
white ZL1 is offline   Reply With Quote
Old 11-27-2013, 09:50 AM   #14
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
Oxygenated fuels are perfect for boost. we see on average about 100+ whp gains going from C-16 to the oxygenated Q-16.
the only time you want to stay away from the oxygenated fuels is running a nitrous application. then you would want to lean more towards C-16,C-23 or VPNOS (designed just for big nitrous applications)
Rdunn
VP Fuels Dealer
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
