02-02-2014, 05:18 PM | #1 |
Drives: 2012 ZL1 Camaro Victory Red Join Date: Jan 2013
Which headers
Ok I would like to get everyone's opinion on which headers I should run on my ZL I would like to have a set that doesn't have a lot of interior drown and should I go with cats or no cats
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
02-02-2014, 07:14 PM | #2 |
Pfadt Tri-Y with cats is what a few guys I know run. Sound mean. However I went with the muffler delete for magnaflow y pipes and fuse pull. Def thinking about Pfadt Tri-y this year though.
2013 Summit White ZL1
02-02-2014, 07:28 PM | #3 |
Pfadt Tri-Y's hands down. Excellent performance and the sound is amazing!! And the belly pan doesn't need to be cut to install them. Here is a link to my YouTube channel with a few sound clips.
http://www.youtube.com/user/swizlstik1/videos
02-02-2014, 07:30 PM | #4 |
Bump
02-02-2014, 07:37 PM | #5 | ||
Drives: Black ZL1 Join Date: Apr 2013
I have American Racing headers, high flow cats, stock cat back, fuse pull(which is where the drone comes from, so leave the fuse) and I'm very happy.
But I can't really argue with the other people's post because I did have to cut out part of the belly pan with the install. About an 8x8 inch patch on the back edge for each side. Don't forget to check out my Roomba, sorry couldn't resist, forgot that video was there.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
02-02-2014, 08:56 PM | #6 | |
02-02-2014, 08:57 PM | #7 |
Drives: VR ZL 1 Join Date: Feb 2013
Kooks 1 7/8
02-02-2014, 08:57 PM | #8 |
Longtube
02-02-2014, 09:10 PM | #9 | ||
Drives: '12 ZL1 #1609 Join Date: Feb 2010
Here is a sound byte taken from earlier today in the wide open position: Gotta love the comment the chick makes as I drive by... Otherwise I will be adding to what I already have so by the end of this month I should have in hand my PFADT Tri-Y's (they are on a long backorder btw) with the offroad connection pipes. No Cats!
Life is too short to drive cars that suck.
My build Thread Last edited by mmarx82; 02-02-2014 at 09:26 PM. |
02-02-2014, 09:42 PM | #10 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
Pfadt! Just got mine and the craftsmanship is 2nd to none, and I've had several different sets of headers. Sending them to Swaintech for their White Lightening coating, really hate to cover such a beautiful set of headers.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
02-02-2014, 10:55 PM | #11 |
Drives: C7 / ZL1 / SS / trucsk Join Date: Nov 2009
Highly recommend American Racing Headers , my last 3 camaros I only used ARH and ARH is the official headers in the COPO's
2014 C7 Stingray 3LT/Z51
2013 Camaro SS 2012 Camaro ZL1 - 850 HP 2015 GMC Denali 3500HD 4x4 2012 GMC Sierra 3500HD 4x4 |
02-03-2014, 08:05 AM | #12 |
I agree I have Kooks 1 7/8ths with high-flow cats, stock cat-back but kept the fuse in. It is very loud on start up and WOT but the closed exhaust flaps at cruise give it almost no drone!!
710 RWHP; 667 torque
Ported Supercharger, Snout and TB Rotofab CAI Kooks 1 7/8” Headers w/ high flow Cats LPE GT9 Cam, BTR Springs and Comp Pushrods 160 degree thermostat 2.55" Upper/9.1" Lower SC pulley w/ balancer LPE solid isolator, ID850 Injectors LPE heat exchanger w/ fans Centerforce Dual Friction Clutch Custom Tune |
02-03-2014, 08:28 AM | #13 |
Blanchard Performance
Drives: 2014 Black ZL1 Join Date: Jun 2013
02-03-2014, 08:36 AM | #14 |
ZL1 crystal RED
Drives: ZL1 2014 Join Date: Oct 2013
if I put the Pfadt or another, I lose power or not?
