02-20-2014, 07:05 AM | #1 |
Drives: 2010 ss rs ls3 red-white rallys Join Date: Oct 2008
With a supercharger...what else to get?
Really wanting to add a supercharger...already have a cam, headers and roto-fab cai. Looking to throw on a tvs23oo Maggie. Main goal is reliability. What else needs to be upgraded to ensure reliability? Have had the cam upgrade for 3 years now with no issues at all and want to upgrade what needs to be on a supercharger install to stay as reliable as possible...saving up now, so in the early stages of research here...thx
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
02-20-2014, 07:48 AM | #2 |
Drives: 2011 Camaro 2SS/RS A6 Victory Red Join Date: Aug 2012
A really good tune!
2011 Camaro 2SS/RS A6/L99 Victory Red
SLP TVS2300 Supercharger 6psi & Coil Covers. Roto Fab CAI. RX Catch can ZL1 Fuel Pump Kooks 1 7/8" LT Headers w/ High Flow Cats Corsa out the back! NT555R 305/35/20 472 RWHP 466 RWTQ 12.11 @ 114.3 MPH 1.81 60' Pacific Raceways Kent, WA 6/6/13 |
02-20-2014, 07:58 AM | #3 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
Fuel supply.
02-20-2014, 08:42 AM | #4 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Budget? HP goals?
Most important is fueling/tune followed by driver mod. Then after that, list goes on and on. Depends on your budget.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
02-20-2014, 09:11 AM | #5 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
what everyone else said plus proper cam grind.
-John S.
02-20-2014, 09:17 AM | #6 |
FreakyFast!
Drives: 2010 2SS/RS S/C NicKey #55 Join Date: Feb 2011
All the above and I'll add "1000hp Axles" to the list.
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper) Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743 |
02-20-2014, 09:35 AM | #7 | |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
The Maggie kits are pretty complete with injectors and the like to do the install on a stock car. Since you have headers on it, and a cam now it is going to require a custom tune. If there was one other thing I would suggest doing while you are in there would be a better clutch. With anything the car will always find the weakest link out so to speak, and most of the time that is going to be tire spin but it will put a bit more load on the clutch depending on how hard the car is driven. If you are wanting more boost than the standard Maggie kit, then you will more than likely have to do the fuel pump upgrade like the twin in take LPE units. Other than that...it's going to need traction. |
02-20-2014, 09:49 AM | #8 |
Drives: Varies Join Date: Dec 2009
Pretty much everyone nailed it on what you need.
Custom tune, fuel supply, Rear suspension to hold the power etc... You will need to upgrade the Roto Fab intake tube to make it work with the Maggie. PM or Call me with any questions. JT |
02-20-2014, 10:21 AM | #9 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
With a cam and other bolt ons on board already, adding a Maggie you will run out of fuel. The "LS9" injectors will not support your needs, nor will the stock fuel pump. So depending on your goals you can address your fuel needs that way, ZL1 pump with the ADM FPCM will get you to 650whp with adequate injectors (85lb+). Beyond that I'd explore the dual pumps etc...
Also if your cam is an aggressive NA cam, you may have to swap it out for best results and to obtain your reliability factor. And most importantly a nice safe tune.
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06 |
02-20-2014, 10:59 AM | #10 |
Drives: Camaro 2SS/RS LS3 AirForce Join Date: Mar 2010
with cam and headers I suggest an OD cog drive with the stock 3.8 pulley
02-20-2014, 11:12 AM | #11 | |
Jim
Drives: 2013 Black 2SS 1LE Join Date: Apr 2013
Rear Suspension
I am new at this so please give some details. Jim |
02-20-2014, 11:23 AM | #12 |
A word of caution! Before getting this thing to stick with suspension and rubber mods.....you may want to look into upgrading clutch, driveshaft, diff, axles. The stock M6 should last a while. Unless you can afford to start breaking the OEM parts.
Consider staying with the factory tires/and eliminating wheel hop and relying on them as the fuse to make your other drivetrain parts last till you can upgrade. YMMV
02-20-2014, 11:41 AM | #13 |
02-20-2014, 11:41 AM | #14 |
Drives: 1999 Trans Am Join Date: Jul 2009
I'd say get a SFI harmonic balancer.
As said. For 550rwhp a ZL1 fuel pump and the LS9 injectors are fine. |
