View Poll Results: Installation
Clamp 13 37.14%
Weld 22 62.86%
Voters: 35. You may not vote on this poll
Old 03-16-2014, 09:05 PM   #1
frank122
Drives: VR 2012 RS
Smile Pros and Cons about exhaust installations
Which do you recommend ? Differences between having an axle back welded or clamped ? Also if i decided to weld them on can i never change it back to stock or will it just be much harder
frank122 is offline   Reply With Quote
Old 03-16-2014, 09:12 PM   #2
orangecamaro12
orangecamaro12's Avatar
Drives: 2012 Camaro 2LS; 2002 Trailblazer
Clamp it, and if you like it then have it welded.
~Rotofab cold air intake~Mrt v2 axle back exhaust with magnaflow resonated x-pipe~Satin Black Powder-coated RS wheels
orangecamaro12 is offline   Reply With Quote
Old 03-16-2014, 09:12 PM   #3
ratfinkharley
ratfinkharley's Avatar
Drives: 15 JKU, 00 S10, 73 Vette, 12 JK
If you have an axle back welded on and later decide to return to stock, you can.
A muffler shop would simply cut out the welded area. Now the pipes will be a few inches shorter, so a sleeve would be welded to join the two ends and cover the gap.
ratfinkharley is offline   Reply With Quote
Old 03-16-2014, 09:20 PM   #4
frank122
Drives: VR 2012 RS
I ordered the mrt v2, I'm sure I'm going to keep it on
Old 03-16-2014, 09:41 PM   #5
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
I recommend getting a clamp-on system but then taking it to a muffler shop for welding ($20-30) if it starts to slip.
6bangerBOOM is offline   Reply With Quote
Old 03-17-2014, 04:56 AM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
IF you are installing MRT's I would highly recomend welding. Most everyone has issues with the passanger one slipping. I tried the clamps and tightening with everything I had, but to no avail it would slip. I gave up and had them welded in place. No regrets and it has been 4 years now.
Old 03-17-2014, 02:02 PM   #7
Skizioli
Skizioli's Avatar
Drives: 2012 Camaro 2LS IOM
Same here put my MRT V2 on and the clamps slipped so it is now welded
2012 Camaro 2LS IOM
Mods: -CAI cold air intake -MRT V2 exhaust
-Custom tune done by Myself with HP Tuners
-Oracle Fog light kit for 2LS -HID headlights
-Heritage grille
-Phastek flat black ZL1 replica rims on Nitto invos (285/30R20) -Eibach pro kit lowering springs
-Stoptech Stainless Braided brake lines -Stoptech Slotted and Drilled rotors -Hawk HPS pads
-VMAX ported throttle body -Magnaflow resonated x-pipe (with Cat and Resonator delete) -Elite Catch can
-Quad tips/1LE Rear Diffuser
Skizioli is offline   Reply With Quote
Old 03-17-2014, 06:16 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Mods:
Old 03-17-2014, 06:19 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
No reason not to weld it IMO. Just be sure it's perfect before you do.
Best regards,
Tyler
888-308-6007
Old 03-18-2014, 08:26 AM   #10
CORSAPERFORMANCE
CORSAPERFORMANCE's Avatar
Drives: 2008 C6 Corvette
Clamp, allows better tip aligning after the systems been driven and warmed up. Also for replacements if you've been in an accident or damaged any part of the system.
CORSAPERFORMANCE is offline   Reply With Quote
Old 03-18-2014, 02:51 PM   #11
Cbaublitz
Cbaublitz's Avatar
Drives: inferno orange lfx 2013
i had the problem of the mrt slipping just had it welded.
Elite catch can. Hurst Short Throw. VMAX throttle body. MRT V2 axle back. CAI intake. BMR sway bars and lowering springs.
Cbaublitz is offline   Reply With Quote
Old 03-18-2014, 06:10 PM   #12
skibik
Guest
Drives: bbbbbb
Ditto on the passenger side slipping. It got to the point that I forgot about it once and it started melting the valence hole where it exits. I like the sound and ended spending $25 and had a muffler shop weld both of them in. Drive around with them clamp if you don't have a problem with them slipping you are set or at least drive around and if you like them then have it welded for peace of mind.
skibik is offline   Reply With Quote
Old 03-19-2014, 01:14 PM   #13
14CV6
Tri-County Camaros
Drives: 2014 Camaro V6
I have a Borla Axle Back clamped at the moment, but do plan on getting it welded for that extra security.
2014 Camaro V6 1LT A.K.A. "Black Assassin"
Performance Mods: VMax Ported Throttle Body | Cold Air Inductions Intake | Borla Axle Back Exhaust | Hurst Short Throw Shifter w/Upgraded Hardware
Exterior Mods: Black Rear Emblem
Interior Mods:Short Shifter | 15% Tint Front and Rear
Coming Soon: Black SS Wheels | Blacked Out Side Markers |
14CV6 is offline   Reply With Quote
Old 03-19-2014, 08:16 PM   #14
frank122
Drives: VR 2012 RS
What are some negatives of having it welded ?
