04-30-2014, 10:37 AM | #1 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
sound difference with just High Flow cats added?
how much of an increase in sound volume would I expect from just high flow cats? like the sound of my Retro cat back but could stand for it to be a slight bit louder, would High flow cats give me a slight sound increase with out CEL and tune being needed?
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
04-30-2014, 10:41 AM | #2 |
Drives: 2012 Camaro SS 45th Anniversary Join Date: Sep 2013
guaranteed it will get louder! as for the cel being thrown, it's a hit & miss. my high flow cats threw a cel, reset them, they still threw again. i will need a tune to disable it.
~ 2012 SS ~ |
04-30-2014, 11:11 AM | #3 |
Better sound, yes! CEL throws seem to be hit and miss from different users. From what I've seen SOLO HF Cats with O2 extenders seem to be the better option for no CEL. Not to say that others have more issues or SOLO has none. It just seems that the users with SOLO's have had less problems. As long as they aren't throwing CELs no tune is needed.
PR
---------------------------------------------- 2014 CRT 2SS/RS 1LE Dual-Mode, Recaros, Sunroof, Nav ---------------------------------------- ZL1 Rockers RPI Stealth Splash Guards De-badged (except blacked-out front bowtie) |
04-30-2014, 11:53 AM | #4 |
Much deeper and louder...warning you though, you will want longtube headers soon after lol...sound is addicting!
Sent from your mom's iPhone
TSP 1 7/8, CNT catback, VMAX, CAI intake, ADM scoop, 3.70s, Adm Tuned(374/391), SLP UDP, 18" nurbs/NT05r's , 3200 stall, Granatelli trailing arms....1/4 mi best 12.7
05-02-2014, 05:22 AM | #5 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
It will sound good and perform even better. Get the Solos. I have not had a cel.
05-02-2014, 07:33 AM | #6 |
Had JBA's on mine, just the right sound increase IMO.
With CAI, Apex scoop, VMAX, and JBA cats my car's dyno numbers were 368/370 factory cats, 391/393 with JBA's. Same dyno. And just like huitt06 mentioned, after one year with the high flow cats I now have ARH long tubes and cam... |
05-02-2014, 03:41 PM | #7 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Here's a couple videos to maybe give you an idea of the sound change...
Stock cats, Dynomax #39494 Axleback, resonator and X-pipe delete http://youtu.be/vPAhHGwcfoo High flow cats added to the same combo from above http://youtu.be/Z6ncc-CQLOo?t=11s I did experience some rasp, most likely because I removed the resonators, but I don't know if even the factory ones would have cured it. I think a Magnaflow resonated X pipe would have helped a lot. |
05-02-2014, 09:10 PM | #8 |
Drives: 2012 Black 2SS Join Date: Apr 2012
Definitely a noticeable sound increase. Really woke up my Solo Mach-X exhaust I already had installed. I just took my Solo HFCs off to install Pfadt Tri-Y headers and if anything my car is now just a bit quieter than it was before with the HFCs. All in all, the Solo HFCs are a great mod if you want power, sound, and able to retain factory warranty with no CEL.
If you have an LS3, I'm selling the HFCs off my car
2012 Chevrolet Camaro 2SS Black | RS Package | Hurst Short Throw Shifter | Sunroof | Polished Wheels Pfadt Tri-Y Headers | Solo Mach X Catback | C.A.I. Intake | Vmax | Apex Intake Scoop & Washer Tank | Tuning by Mike Norris Polished OEM Strut Brace | Black Front Bowtie | C6 Flags Rear Emblem | Black Tail Light Bezels | Window Tint | Stealth Turn Signal Bulbs Ghosted Black LED Sidemarkers | Plasma LED DRL | DRL Harness | ABL LED Dome Light | LED Trunk & License Plate Lights |
05-02-2014, 11:11 PM | #9 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Heres my solo hi flows with the magnaflow muffler delete before headers.
http://youtu.be/U6MB4yUwVKA |
05-03-2014, 09:38 PM | #10 |
Drives: 2014 Camaro 2SS RS LS3, BRM, NPP Join Date: Apr 2010
The Solo hi flow cats on my car with the npp exhaust deepened and increased the exhaust sound some. I installed the Magnaflow resonated X pipe on mine also. I did have a problem with a CEL, but after adding another O2 sensor spacer it has not come back. At least so far.
Experience is the best teacher but the tuition is very high.
05-03-2014, 10:15 PM | #11 |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Mine is loud enough as it has the stock manifolds, Solo HF cats, and the Solo Mach XL cat back.
05-08-2014, 01:01 PM | #12 | |
CAI, doug thorley short tube headers, SOLO high flow cats, non-res X-pipe, and Borla Atak Axleback exhaust:
~ 2012 SS ~ |
05-09-2014, 10:58 PM | #13 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I have whats in my sig. Res Xpipe needed to tame the loudness but mostly t he decel is to much. However I miss the old sound and so do the neighbors!
11-20-2016, 08:37 PM | #14 | |
Drives: Camaro 2SS RS L99 Blk with IOM pkg. Join Date: Sep 2014
High Flow Cats Louder than LT Headers!?!
