05-01-2014, 12:33 PM | #1 |
Drives: 2012 Camaro 2SS/RS IOM Join Date: Oct 2012
Brake System Question
I booked my car in to change out the winter tires and an oil change. They want to schedule me for semi annual maintenance but didn't give the details, plus they want to flush my braking system lines. The car will be 2 in June and has 43K kms. No, I haven't read the owners manual as I haven't had a chance yet. Just looking for some thoughts on this. Just to clarify, its the dealer making this recommendation.
Thanks |
05-01-2014, 12:41 PM | #2 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Do you have an LS3 or L99?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
05-01-2014, 12:56 PM | #3 |
LS3
05-01-2014, 01:33 PM | #4 |
Drives: 2010 Camaro 2SS/RS LS3 IOM Join Date: Aug 2012
I've had my car 4 years now, and have never been told to flush the brake lines?!? Not saying it isn't a possibility though, but then I'm waaay behind
I usually get the semi-annual inspection once a year, just in case they find something I should be concerned about.
05-01-2014, 01:41 PM | #5 |
The LS3 shares the Brake fluid cylender with the clutch, so clutch dust and particulate matter in the fluid can lead to issues.
It is probably unecessary. You can also add a separate clutch fluid reservoir. JDP has them pretty cheap, and it is a simple easy mod to install.
05-01-2014, 02:46 PM | #6 | ||
05-01-2014, 03:59 PM | #7 |
Drives: 2014 Red Hot 2SS/RS/1LE NPP Recaros Join Date: Sep 2010
OP have you ever changed your brake/clutch fluid yet?
Sent from my iPad using Tapatalk |
05-01-2014, 05:12 PM | #8 |
No. I'll get into the Owner's Manual tonight. My car has only ever gone to the dealer for service and this is the first time they are recommending anything to me. I'm happy with my dealer and their service department to date.
05-01-2014, 08:58 PM | #9 |
Which dealer do you go to? I'm booked for a sem-annual at shagannapi on Monday.
05-01-2014, 09:59 PM | #10 | |
What are they charging you for the semi annual? |
05-01-2014, 10:02 PM | #11 | |
I'm getting just the inspection part of the semi-annual, as I don't need the oil changed yet. It's costing me $59.95. I'm also having them check for any oil leaks as my brother-in-law said there is some oil on top and underneath that I should get checked. It maybe just "sweating" but you never know.
05-01-2014, 10:12 PM | #12 |
Well the manual doesn't say anything about flushing the brake lines. It refers to leaks and topping up or rather not to. The maintenance manual refers to checking the brakes only. So I won't be completing that service.
05-01-2014, 10:13 PM | #13 |
Good to know!
05-03-2014, 02:13 PM | #14 | ||
Drives: '14 CRT Camaro SS Coupe Join Date: May 2010
You drive your car as a daily driver? Drive the car hard, like a road course race track? Since you have an LS3: I would strongly recommend changing the brake fluid !!! '09 Pontiac G8 GXP owners with the LS3 & 6-speed stick find if you do not change it enough...If you drive the car hard! The clutch might not fully engage; as the brake fluid heats up :( Plus as a performance car, the '09 Pontiac G8-series in the Australian owner's manual says to change it every 2 years. (Your 5th gen Camaro was R&D by the Australians - Holden.) If you drive it not hard, & it was a 6L80 auto transmission: You could wait until the next brake pad change. But keep in mind brake fluid absorbs water. It you have water in your brake lines...you can have brake failure under hard performance driving. The folks who road course lap their cars: Change their brake fluids every season; if not more.
'14 Crystal Red Tintcoat Camaro SS RS coupe
Former G8 owner :( RIP Sunday, Oct 6, '13 1 of 3,681 in Panther Black Metallic '09 Pontiac G8 GT (with L76 6.0L small block V8 engine & a 6L80 tranny) 1 of 970 '09 Pontiac G8 GT's in the country (Canada) |
