05-21-2014, 07:52 AM | #1 |
Drives: 14 Z/28 0# Join Date: May 2013
Brake Fluid?
I'm leaning toward AP Racing Super 600. What are you putting in?
What's the best? |
05-21-2014, 12:35 PM | #2 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
"Best" wet boiling point, Castrol SRF @ 518f.....AP is much lower at 311f
Dry boiling point is when the fluid is brand new, you want to look at how it performs when wet.
05-21-2014, 01:08 PM | #3 |
Break fluid should be changed because it will absorb water. But why change it when new? Does GM recommend changing it?
05-25-2014, 10:08 PM | #4 |
if you are going to track the car they recommend you put in proper racing fluid...it does not come with it as delivered.
05-25-2014, 10:46 PM | #5 |
Drives: ZL1 #529 "El-Jefe" Join Date: Mar 2012
