10-14-2014, 09:49 AM | #1 |
Endlessly Wrenching
Drives: VE SV6 S2 manual Join Date: Nov 2013
1/4 times for Forced 6s with IPS questions
Hey guys,
I've been tentatively lurking for a loooong time and have been extremely jealous of what you guys do BUT i'll be joining one day i just want to know what kind of 1/4 times the IPS kit is capable of. Will a straight bolt with supporting suspension mods is capable of making the 12 second bracket? would e85 and cams be necessary? and finally, can cats be fabricated for the sake of passing EPA tests without too much problem? |
10-14-2014, 10:02 AM | #2 |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
IPS?? IPS is the Twin turbo, you'll definitely be in the 12's. IPF is the Supercharger, with Headers and suspension mods you'll be low 13 high 12's . I have BBK Headers with low res cats, had them over 3 years, Supercharger over a year , so far cats are still holding up.
" Last edited by gutterball; 10-14-2014 at 10:47 AM. |
10-14-2014, 12:50 PM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Could probably hit high 11s with good tires and a competent driver honestly. 12s all day. Cams don't work in the LFX unfortunately, unless you're talking a custom grind. And no to E85 but I'm sure it could help.
If you really wanted more than 500whp you would just need the LF3 high pressure fuel pump (and forged internals for safety).
10-14-2014, 07:32 PM | #4 |
Drives: 2012 M6 Victory Red Camaro ZL1 Join Date: May 2014
I haven't taken it to the track yet, but if I were to guess my time I would say from 12 to 12.5 seconds and would trap anywhere from 115 mph to 120ish
10-14-2014, 07:44 PM | #5 |
Endlessly Wrenching
that's so awesome! thanks guys. Has anyone done FI with mace cams? might change them with the timing chain. Is the LF3 HPFP a straightforward swap? expensive part? sorry for all the noob questions
10-14-2014, 08:24 PM | #6 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Do you have an LLT engine or the LFX engine?
10-14-2014, 10:04 PM | #7 |
Endlessly Wrenching
10-25-2014, 05:23 PM | #8 |
Silver Ice
Hey, sorry to thread jack, Im a Silver LT with blacked out Tail Lights in Arlington think ive seen you before, thought i heard spooling lol. Where have you gotten your work done? Been trying to find someone who knows what they are doing.
10-25-2014, 06:09 PM | #9 |
Boosted
Drives: 2012 1LT RS... with snails Join Date: May 2012
Hey Gee, Skulka222 got his work done at IPS along with myself. There isn't really anyone around in New England that does real speed shop work on the V6 especially the LLT. Supposedly J & M Motorsports in Manchester CT can tune the LLT with HP Tuners
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani* |
10-25-2014, 06:44 PM | #10 |
Silver Ice
Thanks man. I want to boost my car so bad. Just dont want to do it while i have a payment. With my luck ill throw a rod and still have to pay it off lol. I used to live in pawtucket ri. buddy has a nasty black ls3 swapped 96 ss down there and i go to shows with him every once in a while. def want to check out your ride. you go to any?
10-25-2014, 06:46 PM | #11 |
Silver Ice
hopefully by the time im ready. there will be a twin turbo kit for the llt thats as reliable as the ips build
10-25-2014, 07:11 PM | #12 |
Boosted
I want to a decent amount of shows this summer.
10-25-2014, 07:32 PM | #13 |
J&M did my car with HP Tuner and did a hell of a job. Car is running great.
